instrument panel fogging
/ instrument panel fogging #1
dewald
After using my 4310 for a while,the instrument panel fogs up.Does anyone else have this problem?
/ instrument panel fogging #2
My 2 year old 4300 does that. On one of the tractor boards, it might have been this one, somebody said that JD had a recall or something for that. He had his fixed for free by the dealer. I'm surprised that the newer ones are still having the problem. As I remember the fix was some kind of antifogging dash glass.
/ instrument panel fogging #3
dewald,
Same thing happens on my 4010. The first time I thought it was due to a washing, but it happened again last week after using it to box scrape my driveway in preparation for winter. The tractor hasn't been wet for over a month. I can still read everything, but it does cloud up.
Bob
/ instrument panel fogging #4
My 4300 does that. Like others said, I heard there was a fix. I figure next time it goes in for anything I'll have them do the fix. Not sure what it entails.
Bob
/ instrument panel fogging #5
I had my 4300 fixed two years ago. It was under warranty and did have something to do with a DTAC(?) notice.
I am also surprised the new models still do the fogging. I thought the fix was an anti-fogging coating. It was annoying, and not related to washing the tractor. Best to check with your dealer about the problem.
/ instrument panel fogging #6
The 4700 that I bought this Spring does this too. It does it when the engine is run hard for any length of time and it is annoying but it clears up after the tractor is shut down for a while.
/ instrument panel fogging #7
Here is the case for the hundred series....
I show no cases yet for the 10 series, complain to your dealer, Deere can't fix what they don't know about !
Solution Number: 44806
Doc ID: LV44806
Solution Summary: 4200 4300 4400 4500 4600 CUT Instrument Panel Glass Fogging
Publication Date: Jul 17 2002
Complaint or Symptom:
Condensation builds up under glass of instrument panel.
Problem or Situation:
The glass does not have anti-fog treatment.
Solution:
Replace the glass with a kit that contains treated glass and a new seal.
Parts: RE72944 Anti-fog Glass Service Kit
Serial Numbers: Machines affected are prior to the following:
LV4200C225051
LV4200H221446
LV4300C234709
LV4300H231644
LV4300S236881
LV4400H241444
LV4400S245079
LV4500C250199
LV4500P253528
LV4600C260238
LV4600H266889
LV4600P263421
4200, 4300, 4400, 4500, 4600
ELEC, F1603, GAUGE, GLASS, INST, INSTRUMENT, INSTRUMENTS, DISPLAY
/ instrument panel fogging #8
Just took delivery of my new 4210 in late November. Having the same problem as the rest of you. This is the only problem I've had with the new tractor, definately not earthshattering but at the very least annoying. I plan on having it looked at when it goes in for 50 Hr servicing.
/ instrument panel fogging #9
My 4200 fogs up.. Did not receive any kind of recall.
/ instrument panel fogging #10
Bill,
It wasn't a recall, it was what Deere calls "FIX AS FAILS"
Which translates into , if you complain, we have a cure
/ instrument panel fogging #11
What does John Deere say about the loose wheel bolt problems on the JD 4000 series ?Is there an assigned case on this ?
I did'nt mention on my original post that while my 3310 was at the dealer for the fogging problem,they also worked on or replaced the tilt steering wheel mechanism.They said Deere issued some sort of repair bulletin on it.It did hang up on me until I sprayed some WD-40 on it.
By the way,the instrument does'nt fog up,but Ican still see moisture on the inside.I think I will have the dealer look at it again in the spring,after the threat of snow is over.
/ instrument panel fogging #13
4200 also opaqued since '99 w/heavy dew wihin command and control center. As correctly defined, looked forward to letting my dealer squirm in the face of: "I be b....'n, you be fix'n!" Sure...SantaDeere-a-Clause found a fix to fumducket my freebe...Day before Christmas, a windy Eve in the Gig Harbor, WA climes, 4200 parked 10-15' off the port bow of one of those slick 10x20 tent tarp-shelters w/fabric sides, ends and roof. Shelterfull of junk, tractor exposed to the force 5 wind/rain. So what? With great care I had anchored the legs of the shelter with 8 lashed-on large sizedJohn Deere satchel counter weights.(those pricey and priceless, easy-to-hook-on buckwheats) Plenty of weight to hold down Mr. Tarp Shelter...I wish I had seen the sequential, preternatural physical eventsresulting in: wind flips shelter, weights catapultedinto Roman siege engine ballistics with one payloadweight coming to rest DIRECTLY in the 10-ring, center bull of my foggy bottom, 4200 instrument panel! Merry Christmas. Not a bad shot!
/ instrument panel fogging #14
/ instrument panel fogging #16
Wind storm flung satchel weight onto instrument panel?
OkieG
/ instrument panel fogging #17
Cute (?) But sounds like the insurance company will be fixin, not Deere dealer. I could have missed something here, not sure.
/ instrument panel fogging #19
Did any of you guys take the JD insurance?
Billy
/ instrument panel fogging #20
My dealer said that JD did not have insurance and that they would not let him sell insurance. I had a hard time getting insurance on the tractor as a result. I am supprised to see a reference to JD insurance.
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
203201 (A60429)
203201 (A60429)
2025 Mower King SSAB72 (A60463)
2025 Mower King...
1996 GREAT DANE TRAILER 48X96 SPREAD AXLE FLATBED (A60736)
1996 GREAT DANE...
YARD MULE (INOPERABLE) (A60736)
YARD MULE...
