May 10, 2024 / 5105 throttle tension adjustment? #1 E ericm979 Super Member Joined Nov 25, 2016 Messages 5,932 Location Southern Oregon Tractor Branson 3725H Deere 5105 I recently acquired a 5105. The hand throttle is super stiff. My Branson's hand throttle has a tension adjustment under the instrument panel. Does the 5105 have something similar? Is it easy to get to?
May 11, 2024 / 5105 throttle tension adjustment? #2 H Harry in Ky Elite Member Joined Jan 27, 2012 Messages 2,561 Location Winchester Ky Tractor Allis Chalmers ED 40 https://partscatalog.deere.com/jdrc/sidebyside/equipment/70674/referrer/navigation/pgId/393226569 I know it's there, but I can't tell you how easy it is to get to.
May 12, 2024 / 5105 throttle tension adjustment? #3 Tx Jim New Member Joined Jan 26, 2007 Messages 10,406 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC I think one will need to remove right side cowl to access adjusting nut on throttle tension. https://partscatalog.deere.com/jdrc/sidebyside/equipment/70674/referrer/navigation/pgId/863069585
