Installing Rear Remote Hydraulics on a 110 TLB
   / Installing Rear Remote Hydraulics on a 110 TLB #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
Fellows this is my first dive into any significant hydraulic work. I am posting this up as I progress from day to day. While I have the arrangement planned out and most of the parts on hand feel free to make any suggestions or comments that may help me or someone in the future.
The control valve is a 3 spool Vickers model CM11. I found it in a scrap yard purchased for about $4.
The 1/2” tubing also from the scrap yard. There is no indication of specification or grade of steel. The only reason I suspect they are suitable for use is the the fittings on each end. There were 11 pieces of tubing I found, all the same length and all with 3/4” JIC fittings on each end. The females are braised on.
I decided to use flat face quick connects. These are bulkhead style with 3/4” JIC ends.
The mounting brackets for the valve and couplers are custom made.
I spent the better part of a day studying the best way to arrange the components. This is what I came up with.
I noticed there are two different seat mounting structures on the 110 TLB. I suspect I have the earlier style.
To gain clearance for the steel lines, I trimmed away some of the gussets that support the seat bottom.
The mounting bracket in place for the couplers. I suppose if I need more space I could make an extension to move the bracket rearward.
The mounting bracket for the control valve in place. Like the coupler bracket, it is made from 1/8” sheet steel. I decided to attach with weld rather than screw.
Well, I have decided to make some changes to both the valve and coupler brackets. I designed them without having any tubing or fittings on hand. Now that I do I see a better way.
Unfortunately, my shop is 200 miles away and I won’t be back there for another week. I intend to update this thread as soon as possible.
After a few weeks of fumbling around with fittings and routing changes I have finished the work lines. I wanted to arrange all six lines along side to each other but the valve was too close to where the downward bend needed to be. I could have moved the valve forward but I had done so twice already and didn’t care to move it again.
   / Installing Rear Remote Hydraulics on a 110 TLB #7
Nice, neat job!
Nice, neat job!
Yes, I’m reasonably happy with it, especially as this was my first time bending tubing in such a way. Having worked in metal fabrication for forty years has helped.
I have yet to plumb the service lines. Those lines are 5/8”. I am waiting for a 5/8” bender to arrive. I also wanted to make a cover for the valve. The cover will protect my elbow from the relatively sharp corners of the valve and fittings.
I also need to make three control levers. I have drawn them but those have to be made in my shop when I get there.
   / Installing Rear Remote Hydraulics on a 110 TLB #9
Very interesting. I myself have a 110TLB and i would love to have some extra hydraulic remotes.
Still making intermittent progress as time permits.
The Vickers valve was had without any control assembly. Looking at some pictures I was able to make my own. I tapped 1/2”-13 holes in the hub for a lever arm to be added. A few days ago I found numerous levers at the scrap yard that already had the needed 1/2”-13 thread. The scrap yard god has again provided!
This was a prototype, it works great. I will make two more.
2015 Kenworth T800 National NBT60 60 Ton Six Axle Crane Truck (A60460)
2015 Kenworth T800...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
iDrive TDS-2010H...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
S/A Utility Trailer (A59231)
S/A Utility...
