Installing a ROPS ??
/ Installing a ROPS ?? #1
Rivendel
NW Arkansas
I'm in the market for a CUT for my small acreage and for the $$ will probably buy a gray market tractor, most likely a Yanmar. Are there aftermarket ROPS available? If so, are they bolt on or weld on? I've built roll cages for jeeps and 4x4's which I have trusted my life to on a few occasions, but If a ready made option is available I'd rather use it.
/ Installing a ROPS ?? #2
I doubt you will find either.. especially weld on ones..
Soundguy
I used to own a Ford 3000 and got and aftermarket ROPS which bolted to the rear axle. It was basically 2 "I" beams with a round tube on top. I havn't found anything available for a small CUT though.
/ Installing a ROPS ?? #4
I've heard that Hoye Tractor & Equipment was working on a "canopy support" (can't call it a ROPS because of liability issues) but I've haven't seen an official announcement yet.
(No, I'm NOT a shill for them, or any other dealer)
cvt
/ Installing a ROPS ?? #5
Some models that have US models that are the same have had ROPS available in the past. I bought one for a US-- YM220 and put it on a YM1820.
/ Installing a ROPS ?? #7
For a ford 3000 sure.. even the 1939 9n has a rops available.. for a grey market.. good luck on matching one up.. i'm sure it will be hit or miss.
Soundguy
/ Installing a ROPS ?? #8
I found one at an auction a couple of weeks ago. My friend and I modified it to fit my YMG1800D, but it still needs some adjusting to make it fit perfect. Pictures when its done.
-Frank
/ Installing a ROPS ?? #9
Since your YM240 is a US model you might. They are probably all gone since it is an older model. When I got the one for my YM1820 / YM220 it was around $600. There wasn't many left at that time.
(APPROX. 42) 4X6X16 ROUGH SAWN PINE (A64276)
(APPROX. 42)...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
Bobcat E80 (A64126)
Bobcat E80 (A64126)
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
