Installed a Tiny Tach
/ Installed a Tiny Tach #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
On my PT. Installation was simple, although the tach is bigger than the original hour meter I had. My mounting is solid, but not as nearly as pretty as a lot of the work I see here on TBN.
One note, make sure you measure the distance from the dash to the engine correctly. I never factored in the drop down to the floorboard from the dash and back to the engine. The 8ft of cable nearly did not make it. Also, just because you have an american tractor, don't assume that the engine is. My engine is german and the piping is metric...
The results are it works (at least I think so cause I have nothing to compare it to). Lots of functions so you can set up work times or maintenance times...
Carl
/ Installed a Tiny Tach #2
Congrats!! Only, where are the pictures?! ;)
/ Installed a Tiny Tach #3
Dittos--This sounds very interesting how about some more information and pics.:D Please.
Mike
/ Installed a Tiny Tach #4
Yes, where did you get it, how much? My tach is broken, I think I need new cable, haven't checked yet. Is it mechanical or electric (I'm guessing mechanical since you said something about an 8' cable). Good job.
/ Installed a Tiny Tach #5
It's electric with transducer hook-up. See it here.
Sorry about no photos. I think it was like $65 plus shipping. Love the thing...
First pic is of the connector on the fuel line. Second and third show my mediocre installation... The dash is 1/4" steel.. I am still only good at rough work so I just bolted it on top...
2016 Chevrolet Silverado 1500 Pickup Truck (A61573)
2016 Chevrolet...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
1996 RWAY BELLY DUMP (A63569)
1996 RWAY BELLY...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
1998 FORD AREOMAX 9500(INOPERABLE) (A63569)
1998 FORD AREOMAX...
2020 PETERBILT 367 (A63569)
2020 PETERBILT 367...
