injector pump
/ injector pump
what would you charge to go through my injector pump should I decide that is the problem.
thanks
Curtis
/ injector pump #12
I think your creating your problem..??
U said the rack is free if u rock the pump back n forth..
The pump HAS TO BE bolted down tight inorder to line everything up properly.!!
U shouldn稚 be able to rock it back n forth.!!
/ injector pump
I am talking about rocking in back and forth in my hand. Once bolted to the engine I can still reach through the crankcase vent cover and move it. Once the governor to rack connection is made it will not go to fully off. I did start the engine with the oil fill housing off and found I have very good oil flow. You are right I am creating my own problems.
/ injector pump #14
Oh.. if its tight in your hand, its gonna be tight in the engine..
IF U already went thru the pump.. u did something wrong..{obviously}
2008 Scag STT52V-27CH 52in Zero Turn Mower (A59228)
2008 Scag...
2015 Chevy Cruze Sedan (A59231)
2015 Chevy Cruze...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
1408 (A57192)
1408 (A57192)
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
