Injector pump problem??
/ Injector pump problem?? #11
Stanadyne is a whole lot better at making kitchen faucets than injection pumps. I don't know if Stanadyne bought Rosa Master but I do know rotary pumps are a pain.
/ Injector pump problem?? #12
Well you have to eliminate the check ball as a problem, the easiest way to do this is to see if the engine runs better without the fitting in the pump, you dont have to run it for a half day with the fitting out, you will know instantly when the engine fires.
/ Injector pump problem?? #13
Yessir, time for a pump rebuild, the piece you found of course is the source of the problem, when it starts coming apart those little bits of rubber go straight to the check ball and fouls it up, never saw one come completely out usually just the bits of rubber that stop the check ball from working, but anything is possible I suppose.
YUP!!! $444 later my tractor runs better than ever!!!
Thanks, Guys! Don
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Volvo EC220EL (A60462)
14C SCRAPER (A58214)
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
2012 International Prostar (A61307)
2012 International...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
