injector leaking fuel
/ injector leaking fuel #1
turtleman
LandTrac 300dtc
I have a 95 ford 4630 that leaks fuel from the injector pump when running i have circled in pic not sure if it is something i can fix or do i need to carry to repair shop.
/ injector leaking fuel #2
That is the bolt that holds the head on the pump. You can unscrew the bolt and replace the copper washer. That should seal it.
WASHER​
Part # 81811703
380427S
-replaces #380427S COPPER WASHER
/ injector leaking fuel #3
R u sure its coming from the copper gasket.??
That screw should b a double screw.. w a 15/16 center screw as a bleeder screw..
U may find either or, if u look up a CAV DPA pump..
/ injector leaking fuel #4
Same copper washer assuming the bleed screw is tight. 5/16" btw not 15/16"
/ injector leaking fuel #5
Lol.. u r correct, 5/16.. lol
I couldn’t tell from the pic if the bleeder was broken off or not..(leaking)
/ injector leaking fuel #6
Yeah, me too. Too much dirt on it.
No problem on the size, just typo
I'll try that.
Thanks guys.
/ injector leaking fuel #9
U wouldn’t believe some of the filthy pumps I get.!!
Just DONT DO IT while it’s running.!!
The extreme temp change will lock up the head and rotor.. (main pumping unit)
The place I used to work at charged 50.00 for bringing in a filthy pump.!!
I use to warn the customers to go spend .50 across the street (car wash) or risk an extra 50.00 added to their bill.!!
/ injector leaking fuel #10
I believe it.... I'm in the rental biz but occasionally get customers equipment in for assessment and repairs. If they come in filthy, I explain that they are looking at a minimum of 1.5hr labor up front for me to run it through the wash bay so I can actually see what's going on on top of the 2hr minimum for assessment.
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
Caterpillar Traxcavator parts books (A63117)
Caterpillar...
Caterpillar 980B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980B...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
