injector leaking fuel
/ injector leaking fuel #1
turtleman
LandTrac 300dtc
I have a 95 ford 4630 that leaks fuel from the injector pump when running i have circled in pic not sure if it is something i can fix or do i need to carry to repair shop.
/ injector leaking fuel #2
That is the bolt that holds the head on the pump. You can unscrew the bolt and replace the copper washer. That should seal it.
WASHER​
Part # 81811703
380427S
-replaces #380427S COPPER WASHER
/ injector leaking fuel #3
R u sure its coming from the copper gasket.??
That screw should b a double screw.. w a 15/16 center screw as a bleeder screw..
U may find either or, if u look up a CAV DPA pump..
/ injector leaking fuel #4
Same copper washer assuming the bleed screw is tight. 5/16" btw not 15/16"
/ injector leaking fuel #5
Lol.. u r correct, 5/16.. lol
I couldn’t tell from the pic if the bleeder was broken off or not..(leaking)
/ injector leaking fuel #6
Yeah, me too. Too much dirt on it.
No problem on the size, just typo
I'll try that.
Thanks guys.
/ injector leaking fuel #9
U wouldn’t believe some of the filthy pumps I get.!!
Just DONT DO IT while it’s running.!!
The extreme temp change will lock up the head and rotor.. (main pumping unit)
The place I used to work at charged 50.00 for bringing in a filthy pump.!!
I use to warn the customers to go spend .50 across the street (car wash) or risk an extra 50.00 added to their bill.!!
/ injector leaking fuel #10
I believe it.... I'm in the rental biz but occasionally get customers equipment in for assessment and repairs. If they come in filthy, I explain that they are looking at a minimum of 1.5hr labor up front for me to run it through the wash bay so I can actually see what's going on on top of the 2hr minimum for assessment.
Frontier Root Grapple (A64126)
Frontier Root...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
Unverferth 330 (A64126)
Unverferth 330...
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
