Tiller info on tillers needed
/ info on tillers needed #1
SmokyMtnMan
Western N.C.
Kubota L-4610 Cab
I saw a post in here about 4-5 months ago regarding brands of roto-tillers that were sold under other names. Such as TSC tillers made by King Kutter, etc....seems there was a post regarding a tiller that was sold by Northern Hydraulics
Anyone know who makes the roto-tiller that Northern Hydraulics offers in catalog? seems some of their other attachments are Howse. Was just curious since it seems to be good price and tiller depth is more than KK.
Thanks
/ info on tillers needed #2
Smokey.
I would like to know the same thing. Better yet, what kind of experience do people have the the Northern tillers?
Thanks,
Buck
/ info on tillers needed #3
Check out "howseimplement.com". They seem to make many of Northern's 3PH items. Interestingly, they also sell for cheaper than Howse sells directly...
ok, now I am back to the TSC KingKutter I guess. Seems that NH only carries a 54" tiller and according to their website, that tiller is now $1024 compared to the 2000 Master Catalog i had here showing $824. I guess with a Kubota 4610 with 72" whellbase, I need 72" so that one won't work. TSC wants $1300 for their 72" one.
/ info on tillers needed #5
Smoke man....
I just purchased a King Kutter II TG60 tonight. I just got it off the trailer when the rain decided to come. It is built like a #$%^ brick house! It is supposed to rain for the next 2 days, so that will give me ample enough time to uncrate it, put the gear lube in the gear boxes and grease all the fittings. I gotta check the PTO length, also. I'll let you know how it works, maybe this weekend. It come with a slip clutch and is totally gear driven, not chain driven. I like that.
/ info on tillers needed #6
SmokyMtnMan,
I have KK 72" on my TC40D, works perfect. My only complaint is that it does not have a jack stand and it has a tendency to roll forward ( toward the tractor) when you unhook it. I blocked mine up with some wood then set it down and unhook it.
Nick
/ info on tillers needed #8
Tony,
What did you pay? Where did you get the tiller?
/ info on tillers needed #9
Will I be red-faced if I give the price and find out I overpaid!?! I got if for around $1000-$1100 from Leinbach Equipment in Winston-Salem, NC. I don't know if there are other Leinbach's around, but I have seen listings of other dealers who sell Muratori.
Tony
/ info on tillers needed #10
I just tilled up 10 acres with a new King Kutter II 60" that I just bought last month. It worked great. It is gear driven vice chain so it is very, VERY durable! I think it weighs around #700!! I pull it with a Cub Cadet 7272(27hp) and it does just fine.
Later,
Jerry in Pa
Well I guess i'm going to have to go for KK tiller at Tractor Supply. Not many dealers around here within reasonable driving distance but them. Just had concerns about whether i needed 60" or 72". Seems odd that there's $300 difference between the two.
What's the worse that would be wrong with having to drive over your tilled soil with 60" or does that tiller offset?
Thanks, I looked at those Italian made tillers called "rotary hoes". They looked good but my wife wouldn't let me get an Italian 'rotary hoe"....said the neighbors might talk about us.
/ info on tillers needed #13
SmokeyMtnMn, Almost all of these tillers have a side shift function. Look in the owners manual and it will tell you how to do it. It is not difficult, you just loosen some bolts and slide the unit over. I have an old Befco 50 that I use on a 4610. I just slid it over so it covers the right tire track. This works fine, I could'nt justify the cost of a bigger tiller no more than I use it every year. If you need to till a lot of ground I would suggest a 3pt. disk. You can do it faster and rocks and roots won't hurt the disk like they would a tiller. It is cheaper to buy disk blades than gear parts for a tiller. Thats my 2cents. DN
/ info on tillers needed #14
One thing I probably should explain. Yes the units have slip clutches or shear pins but the tillers have to load up to activate these safeties. These do a good job of protecting mainly the tractor. They will protect the tiller but just like a runner who developes shin splints or knee injuries, repetitive strain on components will eventually cause failure. You should not have a problem with home use but for commercial use you might want to look at a commercial rated unit.
/ info on tillers needed #15
SmokyMtnMan,
I didn't mention to my wife that I was getting an Italian "hoe" /w3tcompact/icons/shocked.gif, I just said I was buying a tiller. She just wouldn't understand! /w3tcompact/icons/smile.gif
my kubota 4610 has 46 HP and 39 pto HP.
KK 60" tiller says .....'horsepower required' : 25-40
KK 72" tiller says......'horsepower requred': 35-50
both have slip clutch and gear drive
60" is 690 lbs, 72" is 780 lbs.
neither has offset, only the 4 ft model has offset
so, with my 4610 having more horses that what is says 'requred' for 60", is that any problem?
such as.....voiding a warranty or being hard on the tiller?
how hard would it be to 'offset' a tiller not made for 'offsetting'?
/ info on tillers needed #17
You need to insure that the gear box and chain drive are rated for your HP. I think most are 50HP or higher
carl
doesnt' have chain drive....it has gear drive
60" says Required HP 25-40....tractor is 46 net, 39 pto
/ info on tillers needed #19
Go with the model that will be covered by a warranty. Manufacturers seem to be going away from sliding tillers. My point was, that a smaller tiller can be used on a larger tractor. I already had an old Befco that would do everything I wanted it to do. It will eventually fail, but it has payed for its self many times over. I do go through a lot of shear pins, that is the price of the higher hp. I do not know how to offset a non- sliding tiller. It will take somebody smarter than me to tell you how to do it. It would probably be cost prohibitive to modify a tiller. You should most likely purchase a tiller that matches your tractor. Good luck on your purchase! Them L4610s are a piece of work, aren't they!
/ info on tillers needed #20
On most tillers there is a gear drive on the top that is driven by the PTO and drives a half shaft that goes to one side of the tiller. Then there is a chain drive from the end of the half shaft to the axle that has the tines. The chain drive is in an oil bath.
carl
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
8'X28" Table with sink and dishwasher inlet (A60352)
8'X28" Table with...
2004 Subaru Impreza AWD Sedan. (A61569)
2004 Subaru...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A60352)
2004 International...
