Info on the GR2110
   / Info on the GR2110 #21
Well in Oregon during peak growing season in the spring we have about a 5 to 6 day cutting cycle and with the 4+ acres and trails added on it sometimes takes two people to do the mowing. Also during the fall I will saddle up the catcher for the leaves on the BX2230 and it stays on until winter and the G2160 fills in and also is used when the BX is setup with the box scrapper, rear blade or tiller. so
*they alternate duties kind of like your setup.
David
Plus since both decks are exactly the same except for the gear box orientation and lift points I only have to stock one set of spare partsKb7uns.
*Sure is handy with more than one tractor isn't it?!
Well I hit up the a dealer and looked all over the GR2110 with a 54" deck. Very nice little mower. Love the diesel. I am really considering this tractor for my mowing needs.
I also looked at a ZTR that I have necver seen up close before. It was the ZG227-54. Really nice. I have looked at alot of ZT's and this would rate number one. The seat is awsome, hyd lift for the deck operated by a foot pedal, shaft driven deck and a Kubota gas 27hp engine. All and all a very nice machine that really looks rock solid.
I could have stayed there all day and drooled.
   / Info on the GR2110 #23
If you buy this you better like reading the works shop manual.
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
E-Z Trail 700 bu Auger Wagon (A59814)
E-Z Trail 700 bu...
