Info on Routine Maintenance 1652
   / Info on Routine Maintenance 1652 #1
DC1652
saskatchewan, canada
MF1652
Hi
First time poster and first time tractor owner...
Purchased used 2012 - MF 1652 (500 hrs) but didn't come with owners manual. Can anyone direct me to a place where I could get a primer on changing fluids, grease points .. and any other general PM's required to keep the tractor in operating condition and away from any major repairs
By the way, I don't know if it matters but it is a Qs series 12 speed ... shuttle shift
Thanks
   / Info on Routine Maintenance 1652 #2
From my phone notes:
Massey 1652
-Engine oil, 10w-30 or 5w40, 8.5 qts, 3/4 drain bolt.
-Coolant: 8 Qts (7.6L)
-Hydraulic oil: 7/8" drain bolt, 8.2 gal. Permatran III (OR Mobil424, Permatran 821xl, Kubota UDT, Deere Hy-Gard J20a, c, j21a... Case Hy-Tran plus, ultra ETC).
-Front axle Permatran III, 6.2 qts, 11/16 bolt.
Oil filter:
Mobil 1 #M1-102
AGCO #3757038M2
ISEKI #6213-240-005-1
DENSO #115010-5250
NAPA #1348
Hydraulic filter:
AGCO #3608996m91
Napa #1664 ($13)
Fleetguard #HF28850
Donaldson #P556005
Wix #51664
Air Filter (cabin):
PF-16892 (6243528M2)
   / Info on Routine Maintenance 1652 #3
Grease points are all pretty obvious, only sneaky ones are the front axle pivot joint, and there's one up under the HST pedals (might be a similar zerk for the Gear models).
Also, I have a thread in here regarding hydraulic maintenance... There are removable, cleanable metal-mesh hydraulic filters underneath the machine. Look up that thread to see what I'm referring to.
   / Info on Routine Maintenance 1652 #4
Massey 1652
Oil filter:
Mobil 1 #M1-102
AGCO #3757038M2
DENSO #115010-5250
NAPA #1348
Hydraulic filter:
AGCO #3608996m91
Napa #1664 ($13)
Fleetguard #HF28850
Donaldson #P556005
Wix #51664
Air Filter (cabin):
I have a different model Massey but was curious how you cross referenced the Agco filters to other brands?
   / Info on Routine Maintenance 1652 #7
Been away for a few days. Many thanks for this great info. Would I be correct to assume that the 1652 HSTC filters are the same as for the 1652 Q series
   / Info on Routine Maintenance 1652 #8
I believe the HST models have an additional filter
   / Info on Routine Maintenance 1652 #9
Also if anyone has a used manual for the MF 1600 series (1652 specifically) for sale, please send me a message ... many thanks
   / Info on Routine Maintenance 1652 #10
I'll snap photos and post them
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2009 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2009 PETERBILT 389...
