indoor snakeskin identification?
/ indoor snakeskin identification? #1
2manyrocks
Super Member
Just found this fresh snakeskin in the vacant house I've been working on and then found another one about 15' away outside by the sidewalk. Suspect I have a pair that's going to mate in the house??? I'm in Middle Tennessee.
Can anyone identify what kind of snake or snakes these are from the skins?
Any suggestions how to get them out?
/ indoor snakeskin identification? #2
Yikes! Hear any rattling noises? j/k doesn't exactly look like a timber or diamondback rattler. But... see any indications of rattles on the tail end?
/ indoor snakeskin identification? #3
What part of the country are you in? That might help narrow it down.
/ indoor snakeskin identification? #4
Can you look at the tail belly section?
A key between venomous and non-venomous snakes is that the non-venomous have a double row of scales.
/ indoor snakeskin identification? #5
Found one in here when it was our weekend place. Actually I found it because a fireplace fan wasn't working and the skin was through the fan. Of course I put it in my Dads GFs bed!
/ indoor snakeskin identification? #6
Thats a from a rat snake they can climb like a monkey, I have them in my barn. You have to find where they're coming in and seal the hole but dont kill them, they are not aggressive and will eat a bunch of rodents. If you have trees near the house they may be coming through the attic.
/ indoor snakeskin identification? #7
Ah - newbury - that's great info. I'll use that to ID the dead snakes - - you can do the live ones.
Thanks for the quick replies. It appears to have a double row of scales on the underside of the tail. I'm in middle Tennessee. Rat snakes are common here. So...rat snake?
From what I read, they mate through July and then can have up to 80 offspring. So how do I get them out of the house???? I've seen some people suggest using a minnow trap with a couple of eggs as bait.
/ indoor snakeskin identification? #9
Unless you have mice or something in the house they are probably outside because they go where the food is. They may just be cruising the house looking for food so unless you can figure out how they got in and seal the hole they will probably be back. You can try the egg in the trap as well, if their in there I'm sure you will bump into them sooner or later, and yes it's definatly a rat snake skin.
/ indoor snakeskin identification? #10
If the snakes are there in the house, you have a mouse problem for sure. Deal with the mice and stop them from entering the house and you won’t need to worry about snakes.
/ indoor snakeskin identification? #12
+++1 on eliminating the food supply (rodents).
Also, most rat snakes are pretty shy. Keep working in the house, banging around, lots of vibration, you will drive them off--then plug the hole
I've had a couple of banded water snakes in the basement, but this is the first time I've seen any evidence of a rat snake. I saw some evidence of mice around February and put out mice poison. So far, I have only seen the snake skin that I posted and not the live snake.
I was getting ready to refinish the hardwood floors with a sanding screen on a buffer. Maybe the vibration and the dust will encourage them to get out. Problem is the snake skin is in the kitchen which is on a concrete slab so it's not going to vibrate like the rest of the house.
