Incessant Tinkering
/ Incessant Tinkering #1
Killer_B
Platinum Member
Kalamazoo Michigan
John Deere 3320
Mowing season is over. The snow hasn't started to fall. So what's a body to do?
My front mount blower is on, and all seems to work. But, I didn't care for the way the hydraulic hoses stuck straight up from the control valve, and became rather tight where they round the front brush guard. So, I installed a couple 45 degree fittings. This put the hoses closer to horizontal and they no longer rub at the brush guard. See attached “before photo.”
See “after” photo.
Also, the quick hitch kit came with a long arm that was to attach to a brush guard mounting bolt at the bottom, and then support the three pronged hose holder (that's a technical term) at the top. I didn’t care for the long arm, so I mounted the TPHH directly to the loader receiver assembly that stays with the tractor. See attached photo.
What now? Shall I launch an all out search for the better valve stem cap?
/ Incessant Tinkering #4
Nice work, that looks good. I am sure your wishing for some snow to blast 70 feet!
By the way, the Mower storage axles I bought from you work great, very handy!
Hey Bandaman,
Glad you like the axels. You all set for winter?
/ Incessant Tinkering #6
Do you have all your lights set up? You can't tackle snow without plenty of lights! /forums/images/graemlins/grin.gif
/ Incessant Tinkering #7
</font><font color="blue" class="small">( Hey Bandaman,
Glad you like the axels. You all set for winter? )</font>
Killer B,
Yep, I am pretty well ready for the snow, see my other post (Fixed the blade up a little)
Maybe if we get a ton this year, I can justify that sweet blower setup that you have /forums/images/graemlins/grin.gif
Surfran,
No lights yet. I can't decide on the right way to do it. I definitely want to mount them to the ROPS, but I'm not sure how. Do you have some suggestions?
/ Incessant Tinkering #9
Since I finally got a digital camera again, I will post a pic or two of mine tomorrow night. I bought magnetic base and take them off for Summer.
/ Incessant Tinkering #10
As promised, here is a picture of the lights facing forward. I use (2) of the magnetic based 55w halogen I picked up at Wally World last year. Being magnetic based, I can change them to whereever I want /forums/images/graemlins/grin.gif
/ Incessant Tinkering #11
Since I had already bought another set of lights from Harbor Freight before I found the magnetic ones, I used one of them for my rear light. I just zip tie it to the ROPS facing backward. It is also 55w halogen, but has a yellow tint.
/ Incessant Tinkering #12
The magnetic ones come with a cigarette lighter plug, but I cut that off and wired all of them to a trailer plug set that I had laying around. Again I take mine off for Summer and only use in the Winter so I want them easy to remove. I just leave the outlet wired and mounted all year around.
Hope that helps or at least gives you some ideas. The magnets are quite strong, but if you have a lot of trees or storage area height concerns, you may want them under the ROPS. I have hit tree branches and moved the lights, but never had one totally pop off.
Surfran,
That's really slick. Two questions: 1. Do the magnets really hold them on well, without moving around? 2. Do you use the stock alternator?
Thanks.
/ Incessant Tinkering #14
Killer B,
Yes the magnets hold very well and I have the stock alternator. I haven't had any issues with the battery or alternator, but only used last Winter. I don't use my stock lights and very rarely turn on my flashers as I live in a quiet neighborhood.
/ Incessant Tinkering #15
<font color="blue"> I don't use my stock lights and very rarely turn on my flashers as I live in a quiet neighborhood.
</font>
How much noise do your flashers make? /forums/images/graemlins/blush.gif
(As I ask this question with my tongue firmly implanted in my cheek. /forums/images/graemlins/tongue.gif)
Don /forums/images/graemlins/smirk.gif
/ Incessant Tinkering #16
Of course they only produce white noise so it cancels out the loudness in loud neighborhoods............ /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Always another smart guy in every bunch!
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
Bush Hog 3715 (A64126)
Vermeer RTX 250 Trencher  (A62679)
Vermeer RTX 250...
Dodge 4500 Bucket Truck (A63689)
Dodge 4500 Bucket...
2023 Bobcat T64 (A64126)
2023 Bobcat T64...
