Loader Inactive Case 580 protocal
/ Inactive Case 580 protocal #1
580Dmountain
west
Case 580D
I have a Case 580D that isn't active. I'm also new to tractors. I've been trying to get over to it and start it up once a month for the past two years for about an hour and work all the hydrolic seals, breaks, steering. I've also read to keep the fuel tank full and add some additive.
The climate here is dry and cold with freezing nights in the winters and dry and warm/hot in the summers.
I'm also aware of keeping the battery charged up.
Does all that sound like a good practice?
Should I be starting it more or less frequently?
Should the fuel be fine having a full tank when I barely use it?
Any recommendations on fuel additives?
/ Inactive Case 580 protocal #2
I prefer to not give advice to anyone that lists their location as NOYB.
Doesn’t sound like a very friendly guy, so I will mind my own business.
/ Inactive Case 580 protocal #3
Kind of hard to tell how long diesel will last, under good conditions maybe over a year. I would say what you are doing is good but I would probably do it less often, maybe every 2 to 3 months. It is not an exact science.
/ Inactive Case 580 protocal #4
I suggest making sure it’s winter grade fuel in the tank and keep doing what your doing.
By the way no one needs to know where your at so don’t pay attention to that!
Like you My actual location isn’t listed I just make it a little less noticeable.
Thank you for your responses.
I'm going to spend some time with it today learning more about the fuel system.
It seems like the worst that could happen is getting an algal growth inside the tank. Or water condensate. Or critter knawing at some electrical or something.
In which case you would just treat it, drain the fuel and replace some filters?
I bought the tractor when I was preparing to build my off-grid place but some things came up and now that project got put on hold.
I love the tractor and hope to have more time to play with it. Two of my friends need some small work done at their ranches eventually.
However, I worry about it just sitting neglected until the day comes when I go to really use it.
I've already had to replace the battery and one of the boom hydraulic with another that started leaking.
/ Inactive Case 580 protocal #6
Ditto !!!
I spent some time with it today like I indicated in this morning's message.
The fuel looked fine. I drained the filters and the fuel looked clean. No water.
One of the boom hydraulic is leaking pretty bad so that's another that will need replacing.
It also looks like the hydraulic fluid level is possibly over full. I wonder if that could be causing the seals to leak.
I also discovered one of the drive belts is barely hanging on there while the other one looks pretty bad.
The Owners Service Manual doesn't have anything on belt replacement but it looks like I will have to pull the hydraulic pump off and possibly radiator. :(
If I'm lucky it looks like I can just pull off the front gaurd panel, unbolt the hydraulic pump and pull it off enough to slip the belts over it's shaft.
I got some more research to do.
I guess I'll just ignore the comments from fried and finn cause they don't seem very friendly nice either. :)
/ Inactive Case 580 protocal #8
One of the boom hydrolics is leaking pretty bad so that's another that will need replacing.
It also looks like the hydrolic fluid level is possibly over full. I wonder if that could be causing the seals to leak.
The Owners Service Manual doesn't have anything on belt replacement but it looks like I will have to pull the hydrolic pump off and possibly radiator. :(
If I'm lucky it looks like I can just pull off the front gaurd panel, unbolt the hydrolic pump and pull it off enough to slip the belts over it's shaft.
I have a similar machine - a JD310 that I treat about the same. No problems. Sometimes it will only get started for a half hour and sometimes I'll use it for a few hours every few months. I'm real careful with the fuel..... Only use automotive diesel from a known good source, and I put in additives for cold weather and to keep it from growing bacteria. So far no problems with the sitting time. I've been treating it that way for about 5 years. I should turn it around so that the sun wears the rubber parts equally. Oh, I do plan to put a cover on the tires and get some sort of cover for the exposed hydraulic hoses. But so far just keeping it shaded has worked well.
On the fanbelt, check with someone before you go do all that taking off of parts. I did a main fanbelt replacement on the JD310. It looked complicated like you describe but there turned out to be a built-in way to wind up the spring-loaded idler pulley using a 3/4" wrench and then that big old fanbelt could be weaseled in without having to remove anything at all. Took about 10 minutes max. Very Clever, those industrial engineers.
rScotty
rScotty
Thanks for sharing your experience.
Good tips on parking in shade or covering hydraulic lines so they don't dry out in the sun over time.
I wonder if there are any very common rodent problems people face to be on the lookout for too.
Based on your comment about "automotive diesel" brings up another question. Is the automobile grade better for fuel longevity than the red dyed farm grade that may have higher sulfur content? From what I just read, the higher sulfur content in dyed kind helps in lowering microbial activity but I'm not sure if that's true or not. Maybe an additive will be just as good.
For the fan drive belt, that does sound like a nifty time saving design you have there. I have been researching mine and while some people do drain the system and remove the entire hydraulic pump it looks like it's possible to just take out 4 bolts on the hydraulic pump coupler that is attached to the pully. Then if you are lucky you can slide the pully forward on the pump splines to get enough space for the belt to come through. May also be able to just detach the pump without disconnecting any hydraulic lines to give a bit more room. The downside is not being able to inspect the condition of the pump splines and coupler and also repositioning it for faster wear.
I'm new to tractors but I enjoy doing this stuff. The problem is always living in a condo and not having anywhere to store/work on my equipement that is close. I had to drop the transmission and replace the clutch to my truck this summer in the dirt yard of a friends house. Something I had never done before but came out great. This is why I bought the tractor to build a place to move to my property so I can actually do stuff. :)
Thanks again.
/ Inactive Case 580 protocal #11
Thanks again.
As to rodents, we have pack rats in the mountains. They like to build nests anywhere and eat anything. For some reason, they particularly like to build nests on top of batteries. I've heard that the smell of a ferret, skunk, or weasel dung will drive them away. So far I've just put up with rodents, but someday I may show up at the pet store with a 5 gallon bucket and an odd request.....
As for diesel, it varies because the standard defining what is diesel is itself so vague. Diesel fuel is just a mixture of organic hydrocarbons with a carbon number in roughly the 12 to 20 carbons per molecule range. That's a huge spread.
Although the mix varies a lot place by place and manufacturer, it all works surprisingly the same. Some % of the diesel molecules in the mix will have a different structure so that have aromatics and sulphurs riding along on the basic carbon chain. Those "rider"percentages are controlled more than the actual fuel itself. You can smell the difference. BTW, the more carbons the heavier the substance. Lighter diesel are the more evaporative liquids like acetone or gasoline (another mixture) and heavier are bunker fuel, oils, and tars all the way up to road tar. Some states will die the diesel to identiy it for tax purposes - that doesn't change how it works. Others don't, and there are some areas that still divide the 12 to 20 carbon molecule structure into #1 vs #2 (light vs heavy) diesel, and some divide it farther.
I buy automotive diesel from a station that I think has new tanks just because it is likely to be from cleaner and less water. It's a gamble. I buy in 5 gallon containers and after they sit a few days I scrutinize them for water and crud in the bottom.
I don't use the last of the fuel in the bottom of any container or tank.
Once in the tractor, I add a winterizer and some extra lube. Our climate here is very dry, little condensation, and so bacterial growth in the diesel isn't the problem it is a lot of places. So I don't have experience with the whole problem of bacterial growth. YMMV. Since diesel varies so much place to place, the best you can do is ask around your own area for what local people do for the local challenges.
I'm surprised that Case580 hasn't followed the JD310 on the clever way to do a fanbelt change. It sure is easy on the JD; doesn't even require removing a single bolt. Crank the idler in with a wrench to un-tension, remove that big old belt, replace with a new belt, and then let go the tensioner so that it retensions itself perfectly and automatically. Really, ten minutes is stretching it. But then no other car, truck, or tractor manufacturer that I know of has done it that way either - although I hope to hear otherwise.
Yeah, mechanical things make a great hobby. And all it takes is some dirt and someplace to store a few tools. Here in North America weare real lucky to be able to buy property, and then use it without much interference. I'm just beginning to realize how unusual that is.
rScotty
/ Inactive Case 580 protocal #12
All Diesel now has the same sulfur level. This wasn稚 always true, though.
In many, if not all areas home heating oil is the same as off road (dyed) Diesel, ie on road but with dye added.
Has to do with potential pipeline and storage tank contamination, as well as economics of sales volume of the different products.
What about painting hydraulic hoses white to keep the sun reflected off of them keeping them cooler?
(10) UNUSED 2.5" RATCHET STRAPS (A60430)
(10) UNUSED 2.5"...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 Versatille 260 (A60462)
2017 Versatille...
