Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #1,391
Added a 15GPM filter, grease fitting to thumb mount and cut and re-welded thumb bracket. Really dumb design not allowing the thumb to go further back in the up open position. I was able to get about 6 more inches which helps for fully extended digging. Also added square stock between the thumb to keep it from getting mangled again hopefully. 13 hours on the new machine without issue. It does however really heat the oil up over 180F with a lot of dozing even with a cooler and fan.
Picked up the same model as you. So far I like it but I have the same issues with the thumb. It looks to me like they just slapped a hydraulic cylinder onto a mechanical thumb without any consideration of how far it would go back. Do you have any pictures of the mod you did to the thumb to make it retract more.
   / Importing and modifying a new mini excavator from China #1,392
Thanks
2.5 M Tons.
Yes, kinda looking forward to Pilot Controls, extra pump, and Swing Boom upgrades. I just wish that the Auctions Sales were closer
   / Importing and modifying a new mini excavator from China #1,393
Thanks
2.5 M Tons.
Are you close enough to pick it up yourself or do you have to have it hauled? Is that the one with the twin cylinder gas engine or is it a diesel? What is your total cost going to be for that machine?
   / Importing and modifying a new mini excavator from China #1,394
I can pick it up myself, 14 hours each way, so 2- 2 1/2 days.
V Twin Gas, Honda Knock Off not exactly sure the HP but I am guessing 25ish. No AC or Heat, but I imagine Heat won't be an issue. Big Hydraulic Cooler, Stacked Pumps, Ducted Air Cooling
Any Ideas on the Canister coming from the Cooler? Looks like a Pall type Filter but I have never seen one before
I am into it for under $10K CDN Tax and Fees incl, but + Freight.
   / Importing and modifying a new mini excavator from China #1,395
installed seat belt. almost got bucked off a couple times.
   / Importing and modifying a new mini excavator from China #1,396
I can take a pic but if you can cut and weld its not hard, just a bit time consuming.
The plate that the cylinders ears are welded two between the thumb fingers was cut off and the front towards the bucket cut flush with the ears. I then welded the plate flush with the grabby side of the thumb and slide it as close to the boom as I could and still be able to rotate. It interferes much less with extended digging with how I modified it. After I straighten out the thumb I welded a bar (old pulverizer tooth) between the fingers to help it from splaying out again.
The air duct for the flywheel fan looks well-made. I have never seen any V-twin gasoline units in any excavator. I hope the hyd pumps are properly sized for the working RPM of the engine. These engines are are smooth, quiet, fuel-efficient, and cheap.
   / Importing and modifying a new mini excavator from China #1,398
I have 1 in my Stand On, with the Stacked Pump also. I don't think they need 25hp, but maybe. I can always investigate more flow to match HP. 13.5hp Briggs is better on fuel
One thing you get with a 2-cyl gas engine is decent power even at lower RPM. So, you don't have to run it at rated speed (3600).
Recently I put a new Predator 670 twin into a DitchWitch SK500 walk-behind tracked skidsteer. That's a 1-ton-ish machine, but all-hydraulic, including pilot controls. Nice engine, and only $900 new. Maybe more now. Way cheaper than the Honda GX630 it replaced.
Yeah, the 420 thumpers should use only 2/3 the fuel.
   / Importing and modifying a new mini excavator from China #1,400
I am not sure of the Brand of the Knock Off yet, my Stand On and Mini Wheel loader had the 739cc Rato.
I hope that 1 pump is dedicated to Travel Motors, if not that is my first task
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
Arctic Cat 650 w/Plow & Sprayer (A55272)
Arctic Cat 650...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
