Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China
First up is oil filter.
Oh, good, they have a hyd oil filter. On the return hose, or suction Hopefully the former. Also shows why they did not duct the flywheel fan to the outside, as they did with the ChangChai diesel thumper.
Or, is that what you did, since it came with no hyd filter?
   / Importing and modifying a new mini excavator from China #482
Main cooling fan draws 6 amps and blows 1750 cfm, according to the maker.Not sure about the amps but it puts out alot of air.
   / Importing and modifying a new mini excavator from China #483
No oil filter. everything you see is my own handi work.
   / Importing and modifying a new mini excavator from China #484
I wired everything on the left side.
.No other way to do it and keep things tidy.
Wired right off the alternator and put in switches for each fan.
   / Importing and modifying a new mini excavator from China #485
Still going to cut some more openings for more air flow.
   / Importing and modifying a new mini excavator from China #486
Almost forgot, I motored around on the mini for 15 mins this morn to see how hot I could get the oil. Track motors really heat up the goo. Never got above 35c. Feel pretty confident I've added a few more years of use to this mini.
   / Importing and modifying a new mini excavator from China #487
Heat is the Enemy for mine also, and mostly Travel Motor caused.
I got a lot of work done this weekend with the Mini Geisha, but there was many stops or drive through the Beach washing the track and cooling the oil.
So a Hydraulic Cooler is definitely in the future. I like your external mount Fredrick, however on my unit, I wouldn't be able to take the back Casing off if I mounted it there. Not much room inside either.
Hum, I just learnt that a Agrok QH12, is nearly Identical to my JF12 however, the QH12 is missing the Filter
   / Importing and modifying a new mini excavator from China #489
What did you use for the wrap?
It's called Safeplast na ,also called spiral hose wrap .
Sold on amazon by Safe-Spiral store ,25 bucks for 25 feet. Holds up well in the sun.I've used it before. Good stuff.
   / Importing and modifying a new mini excavator from China #490
It looks to me like the top of that panel behind the seat might work .
You need to find some hydraulic quik couplers , they are like air tool couplers but for hydraulics. Then disconnect cooler to remove panel.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
Lely 1250 (A56469)
Lely 1250 (A56469)
40 ft. Shipping Container (A55973)
40 ft. Shipping...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2016 Land Pride RCF3010 (A53317)
2016 Land Pride...
