Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #241
I had gotten Loongsheen and Hightop into a bidding war. They really didn't move much on their price, but Loongsheen kept throwing in attachments for me. I'm happy with my machine can't speak for the Hightop. I would make sure you can get the spin on filter put on there or see if they would use NPTF fittings. From what I can tell so far it's going to take 5 fittings to go from metric to NPTF. Three on the tank side and two on the hose.
So what prices are you folks getting, shipped to the US? I'm getting quotes all over the place and almost all don't match what's on the site.
Also, what are you recommending for spares/accessories to buy with the unit?
First time buying machinery on Alibaba, thanks for the help!
I talk about the spares I bought the first time, and then the second. For sure, hoses and tracks, in addition to the attachments you want.
I do wish that I had purchased seal kits for the cylinders. Buying parts after the fact is problematic if you can not go thru Alibaba. You are forced to wire funds, since you can not open a Chinese bank acct.
BTW, one guy I know in the UK has had to re-seal the wheel motors on a unit that has no hydraulic pressure filtration. His spool valves are also getting a little "sticky".
Note that shipping costs to Omaha are going to be substantially different than shipping to Miami or LA. Customs, tariffs, taxes, logistics will cost more than shipping.
   / Importing and modifying a new mini excavator from China #243
Those are good suggestions, thanks! How long it took for you to have to change the seals, just curious?
I was asking about the item price, in general. Shipping quotes are pretty consistent for me, the excavator itself is the one that varies all over the place. Even for the same engine I get up to $2-3k differences.
I did not buy seals from China, since I had no reasonable way to pay. I was quoted 4 kits at only $60, shipped DHL. I buy most of my seals by size from Hercules. I just finished a Kubota loader cylinder re-seal, and I might have taken an hour to do it. I do boil the piston main seal in water and clamp it to cool. My XN08 bkt cylinder leaks but not enough to be an emergency.
I see base prices for 1T minis ranging from $3500-5000, FOB Qingdao. There are differences between units: engine, Hyd oil filter, hyd oil cooler, etc. I see that Xiniu has upgraded the XN08 that I bought to the XN10. I see changes to the house, plus use of some Eaton hyd components.
   / Importing and modifying a new mini excavator from China #245
I have read through this thread a couple times. Made an account with a customs broker. Currently have discussions going with 3 sellers on Alibaba.
I have read through this tread a couple times. Made an account with a customs broker. Currently have discussions going with 3 sellers on Alibaba.
I would be curious if or when the 25% tariff goes away now that there is a new China-friendly administration.
   / Importing and modifying a new mini excavator from China #247
I have been dragging my feet on this due to the complexity and also hoping the tariff will go away.
   / Importing and modifying a new mini excavator from China #248
Which broker are you using, if you don't mind me asking?
Looks like they are putting the 420cc B&S engine in it, isn't 14HP underpowered?
The usual ChangChai or Koop 500cc Diesel engines are only about 10hp, but make their power at lower RPM. The 420cc gasoline thumpers are 14-16hp and have plenty of power, but need to run a bit faster. I asked the makers to reduce their 6.5cc/rev gear pump to 5.5cc so it is less jerky.
   / Importing and modifying a new mini excavator from China #250
My 5 ton excavator is only 38 hp. 14 should be enough power for a 1 ton machine.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2019 Grove TMS500-2 40 Ton Hydraulic Truck Crane (A60460)
2019 Grove...
John Deere XUV825E (A56438)
John Deere XUV825E...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2007 Peterbilt 379 T/A Day Cab Truck Tractor (A60460)
2007 Peterbilt 379...
