Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #171
Our purchasing dept at work has issued a memorandum about no more ordering from Alibaba or Aliexpress. They said their credit card gets scammed every time they order. No more.
   / Importing and modifying a new mini excavator from China #172
Yes I'm from Denmark.
I did choose Sany because they seemed to be one of the biggest in local China, and I thought that at least couldn't hurt.
And I saw a video on youtube with the SY16C, where it did have nice smooth movements, something that in my opinion, the smaller 1ton mini excavators do not have, they seem to have - not sure if I say it right, non fluidic movements :)
But you can comment on that one concerning the XN08?
My reason for attempting to buy directly from a dealer in China, is that I have seen Chinese machines, sold locally in Denmark to what roughly is 3 times the price that I see on alibaba, hence I would expect there is at least some money to spare.
But as you say, quality control is something you should be aware of.
But the problem buying from a unknown seller is that you have no idea what you get, and it's no limit on how bad a Chinese lookalike can be, you must be prepared to write of the whole machine on a very few hours if you are not lucky.
Yes, indeed, the movements of the boom and dipper on the 1-ton units can be pretty jerky or non-fluid. The reasons for that are the extremely light weight, and the directly controlled spool valves. The spool valves also have no shock-relief valves, aka work-port RVs.
In contrast, bigger excavators usually employ servo-controlled valves and shock-RVs, which both help smooth out the movements.
On the one-ton minis, one pump does all the work, so simultaneous movements require a steady hand to feather the joysticks. This takes more practice, but one does improve.
Those familiar with backhoe attachments on compact tractors usually suffer these same limitations, except for the much greater weight.
I hear you. The Sany prices I see in the US are indeed less than Cat, Kubota, Deere, Tak, etc, but not a lot less. I do not know what your repair and maintenance choices will be if you buy direct from China. Based on my experience, I would buy a larger mini from Xiniu (Shandong Landworld) if I were looking for one. Consider the XN12 or XN16, both of which use the Yanmar 3-cylinder diesel engine. Of course, you are looking at 50-100% more in cost.
I bought the yellow mini with a mechanical thumb (post#21), but I went with a hydraulic unit that I fabbed up. (Once you've gone hydro, ya can't go back.)
Well, the black mini, which I have just sold, needed some kinda thumb, so I modified (fixed) the yellow one and installed that one.
The yellow one included a main pivot plus 6 pin tabs welded to the dipper. Problem was you have to remove the brace entirely in order to fold the thumb into the storage position against the dipper. Furthermore, the thumb itself would not survive anything but the gentlest service. It was a 2-piece design with no bracing between the sides.
So I welded different pivots onto the dipper, including 2 tabs to hold the brace in rest position. I also welded a face and braces to the sides.
   / Importing and modifying a new mini excavator from China #176
Have you considered using carriage bolts on that bucket?
Carriage bolt heads would leave a much smoother surface, so that excavated material would not be as likely to stick in the bucket.
Have you considered using carriage bolts on that bucket? Carriage bolt heads would leave a much smoother surface, so that excavated material would not be as likely to stick in the bucket.
I have eliminated bolted teeth in both of my buckets, the one for my backhoe, and the one for the yellow mini. See above.
It is not only to reduce the problem of dirt hanging up on tooth bolts, it is so I can use better teeth. The teeth you see here are cast steel, but not as soft as other bolt-on teeth I have owned in the past.
   / Importing and modifying a new mini excavator from China #178
And Plow Bolts would eliminate the protrusion of the head entirely making for a smooth surface.
   / Importing and modifying a new mini excavator from China #179
Well, still no rain here, so I have not had the chance to extensively use my new machine. I have
done some work on one of my trails, by dampening the ground with water siphoned from the creek,
100 feet away. This trail is about 40% grade (5/12 pitch) and 4' wide. The bottom of the photo
has a 3-foot level to indicate slope. The photos do not do justice.
I have used the time to go leaf-peeping in New England, and nearly complete a hydraulic thumb
for this machine. I hope to test it in the next few days. I will post a new thread on that, or put it
here.
Hey dfkrug Thanks for all the Info, been following this Thread for quite some time. I actually imported a HT10 and it is very similar to yours with alot of the improvements you made already done by the manufacturer. I will post some pics later, I have a question did I read somewhere that your extended the tube that fills the hydraulics fluid? reason I ask is when I was digging on a steep slope like you mentioned above i had some hydraulic fluid coming out the fill tube. Have you had this problem, what does your set up look like? I will post a pick of mine later as well.
Thanks!
Yes, please post some pix!
You have a "HighTop", and I have been in contact with them as well. I tried several times to meet up with a guy who imported several of the HTs in wine country, but I have not been successful. This company has made serious efforts to meet requirements for US export, incl CARB/EPA gas engine.
I have overflowed the hyd fill tube only when adding fluid, so yours must be quite different.
Pls post your location and tell us more.
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56438)
2017 John Deere...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
VOGELE VISION 5103-2 ASPHALT PAVER (A60429)
VOGELE VISION...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
