importance of position control
   / importance of position control #11
How can a 3-point even be used without position control. In my case - be rather difficult to connect up any of my 3-point implements - they weigh from 730# to 1050#.
Now draft control - totally different operation. I've used it with my moldboard plow. I guess it works OK - until the plow encountered a large rock - trips and I have to reset and start all over again.
All my land engagement 3-point implements do a good job without draft control. I can see its use if I were plowing large, rock free fields with a multi-bottom mold board plow.
My operators manual has a very precise/adequate description of both position control and draft control.
JMHO - but some are confusing position control and draft control. I would almost guarantee - if your tractor has a 3-point system - you have, at least, position control. You may/may not have draft control. Think about it - - if you have a 3-point system - how do you raise/lower any attached implement. That lever you just grabbed to raise/lower the implement is your position control.
Why do we continue to disagree when its as simple as reading the appropriate section of your Op manual.
   / importance of position control #12
I agree that every tractor with a 3pt lift should have some sort of position control built in. But maybe you and I are wrong and the SCUT BX models are different. Frankly, I don't know....but this much confusion can't be good. It could be that they only lift all the way up with nothing in between? Anyway, that's why I described EXACTLY how a 3pt position control should work about 2 posts back from this one this morning. And then I'm asking the two BX owners who posted here if that is how their BX 3pt works. Then we will know more.
BTW, I think the draft control on my JD might/might not work differently from your Kubota? The JD doesn't "trip" or "reset".... but I guess you could describe the action that way. It sort of depends on how it is described.
Anyway, here is what the JD draft control does:
To start, you set the draft control whatever amount of resistance that you want it to respond to. Then set the draft control lever to "on". Now when the plow hits a tough spot or a rock, first the tractor slows down and next the 3pt draft control hums as it rapidly raises the implement starting with a rapid fire series of small increments of maybe 1/8" and then if that doesn't help it makes each raising increment larger until about two seconds later it might be raising the implement several inches at a time. THe whole process happens very quickly because all the time the tractor is trying to pull the implement through the dirt.
From the seat all you feel is the tractor slow down and then hear and feel the jerking of a rapid series of hydraulic actuations.
As soon as the tough spot is passed, the 3pt automatically returns the implement to the previous depth.
Does that sound like how your Kubota works?
rScotty
   / importance of position control #13
No, no - rScotty. I can see that my explanation can be misunderstood. My draft control does not trip or reset - its my moldboard plow that trips and I have to manually reset the plow.
When I've used draft control - its never been as exotic as you describe. The plow hits a buried rock - the plow trips - I have to stop and reset the plow.
The way you describe it - that's the way it would work if I had an area that was free of big 'ol rocks. When I have draft control engaged - hit a big rock - plow trips - tractor continues on as though nothing happened. The tractor does not care one little bit if the plow is doing a good job or not. As a matter of fact - the plow trips - draft control sees little or no resistance and the lower arms drop to the lowest setting that I have set with position control.
I sure have no knowledge of what type of 3-point system the BX might have. If they have a 3-point system - there must be some way of raising/lowering the lower arms - you would think.
   / importance of position control #14
Position control means there is feedback to the 3pt control as to position, it allows one to repeatedly drop the implement to a predetermined point, also allows it to compensate for leakage. It's very handy if you are doing things like spreading and can constantly drop the box blade to say, 3in above grade for example.
My tractor has a 1/4inching valve, basically it's has a detent that allows approx a 1/4in of movement, other then that it operates similar to a single acting valve where it holds one you center the valve.
I wouldn't buy another tractor without it.
   / importance of position control #16
Scotty -- I am sure you really meant some companies have been (as SDT said) leaving off DRAFT control on many models, not POSITION control.
ERROR MY MISTAKE; SDT did talk about Position Control being removed from many SCUTs. I back off and say I'm not aware of that stuff. My 30+year understanding is what I originally described below.
I have yet to ever see a tractor with an hydraulic 3pt hitch that did not have position control. I'd be curious what tractors are being made without position control (if you really meant that.)
Gary: None of the 3pt lift controls are made for "full up or full down" with nothing in between. At risk of offending the intel of many readers who know the what and why of Draft control, I'll comment as follows:
That is my point. If they didn't have position control, you would have only full up or full down. I don't think that there is any tractor made with a 3 PH that doesn't have some form of position control. Now most small tractors likely wont have draft control unless it comes as an option. Draft control wont function without some pretty good traction and I doubt that a SCUT would have enough traction to engage the draft control function effectively. Be it 1/4" inching as per Kubota or whatever, it has position control if you can lower the implement to a position somewhere between full up and full down. The tractor may just have a simple set screw to tighten up at the prescribed point that you can return the lever to that position after raising the implement. Basically if you only have one control lever, you have position control. If you have two then you have position and draft control.
   / importance of position control #17
Not according to the manufacturer's, they make a distinction between non position control, 1/4in, and position control.
Just because the 3pt will hold a position when the lever is centered doesn't mean it as position control (since it has no control over the position of the 3pt outside of operator influence)
When looking at tractors, the manufacturer makes the distinction and uses this terminolog of non position control, 1/4in and position control.
The OP never mentioned draft control so I'm not sure how that made it into the discussion.
   / importance of position control #18
BX models do not have position control. The system used is likened to a single acting remote circuit with power up and gravity down with drop rate control, repetitive implement positioning is up to the skill of the operator, lift arm position is not relative to the control handle position.
Is position control necessary? This is up to individual opinion,,, I have both, yes the position control is nice and I wish the BX had it but it wasn't a deal breaker so I see it as not necessary.
   / importance of position control #19
Trying to understand this.
Sounds like rScotty was referring to "position control" as simply the ability to adjust the position of the 3PH up-or-down-or-somewhere-inbetween using the lever.
Sounds like there is also a more advanced "position control" that does some kind of automatic adjustments (without operator input?) to maintain the implement at a constant height above the ground? If so, I wish I had that feature. Sure would help with box-blading!
   / importance of position control #20
This is draft control, usually found on ag tractors essentially it senses load through the top link of the 3pt, as load is applied to an implement say a moldboard plow a hard spot forces the top link towards the tractor and usually some sort of feedback linkage to the hyd control valve and it automatically makes adjustments to help with loss of traction. There is operator input, one must set up the control sensitivity for the job.
BETSTCO FMN120 -4' FINISH MOWER, 3PT (A52708)
BETSTCO FMN120 -4'...
2020 DRAGON ESP...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
