implement arm won't lower
/ implement arm won't lower #1
iammike
B7100 hst implement arm raises but doesnt lower. I suspect the control valve.has any one else run into this?
/ implement arm won't lower #2
Have you checked your Rate of Drop (ROD) knob to make sure it's not all the way closed? This knob controls the speed that the arms lower at and can stop them from lowering if completely closed.
Yes, I even backed it off counter clock wise to be sure. It was working and then Quit as I was finishing up my drive. It was also making noise when I lifted the blade.
/ implement arm won't lower #4
I saw that you also posted in the Hydraulics forum. That's probably a better area for this, so I'll watch how this comes out in that thread.
/ implement arm won't lower #5
Normally found under the seat, in the middle...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
2022 EZ-GO ELITE...
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
