implement arm won't lower
/ implement arm won't lower #1
iammike
B7100 hst implement arm raises but doesnt lower. I suspect the control valve.has any one else run into this?
/ implement arm won't lower #2
Have you checked your Rate of Drop (ROD) knob to make sure it's not all the way closed? This knob controls the speed that the arms lower at and can stop them from lowering if completely closed.
Yes, I even backed it off counter clock wise to be sure. It was working and then Quit as I was finishing up my drive. It was also making noise when I lifted the blade.
/ implement arm won't lower #4
I saw that you also posted in the Hydraulics forum. That's probably a better area for this, so I'll watch how this comes out in that thread.
/ implement arm won't lower #5
Normally found under the seat, in the middle...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2006 Ford E-350 Passenger Van (A64194)
2006 Ford E-350...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
Cattle Feeder (A65640)
8x18 Meyer 1200 H Farm Wagon (A65579)
8x18 Meyer 1200 H...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
