iMatch Quick Hitch
/ iMatch Quick Hitch #21
tomtomtom,
Thank you. No mention of that by my dealer. I'll have to check into what is entailed in the "System Kit" and the cost. Will let you know, if I find out 1st.
Tom
/ iMatch Quick Hitch #22
I recently purchase a new iMatch for $180 from my J.D. dealer. As for the $'s, I also purchased a 47" front snowblower (dealer obvioulsy had some wiggle room). As for its convenience, it is worth every penny when picking up iMatch compatible equipment. No more kicking, swearing, lifting, and grunting.
However, I have a 1060 Frontier Grooming mower I have not used the iMatch on yet. Dealer said a customer did but, had to rig a chain to the top pin on the top hitch plate and to the iMatch to allow the mower to float properly. So far, he has not remembered exactly what that customer rigged. I don't see how one connects to/picks-up an attachment that needs to float from the 3PH center link with the iMatch. If any one knows a good scheme, I'd appreciate the knowledge.
Tom
JD4115, FEL, BH, 1060 Mower, FM 47" Blower, 60" R. Blade...
beenthere, Thank you. Sorry I'm so thick though. I don't envision what the top (center) hook on the iMatch is lifting. The Frontier has a swinging bracket (upside down "U") with the center lift pin through the "open" end. 3PH center link connects to that pin normally. When using the iMatch the center hook is open, as you know. I am not seeing what keeps the mower's swinging lift pin from slipping out of the iMatch center hook. /forums/images/graemlins/confused.gif
Tom
At least on mine the top link claw WILL not engage the 1060's upper link. it will lay in the claw with it on the ground but as soon as I try to lift it , the pin rolls up the back side of the claw and disengages. I also notice that the Imatch hits the driveshaft. the lower pivot links aren't all the way down yet either.
I was thinking about eliminating the factory mast from the mower and adding a shorter one that pivots on the lower link pins and using chains from that to the back of the mower. Then I still have to think of a way to limit the lower link pivots so the DS does not hit the Imatch. The only other option that I see is to buy the conversion kit from Deere!
/ iMatch Quick Hitch #23
scrappy, welcome to the forums. I guess I never got back on this thread after I DID BUY the conversion kit. I can't remeber what I paid. It was less than list as only after looking it up did the dealer realize he should have told me about the kit and the i-Match would not work with the mower, properly, without it. A bit of a pain to remove the old float arms, etc... but once installed the kit works fine. The only problem is that I do have to get off the tractor an yank the upper arm forward for the i-match upper hook to grab it. The lowers line up fine. Dropping the mower is the same, in reverse. Bottom hooks will release but I have to get off and lift the upper mower float arm and pull back to disengage from the i-Match. I've learned to live with it now I'm pretty quick at it.
/ iMatch Quick Hitch #24
I've got a quick hitch on my 49 HP that I purchased from Harbor Freight on sale for $69.95. I use it on an 8ft rotary mower,6 ft tiller and 7 ft blade. I haven't torn it up yet and it has an adjustable toplink hook. Nearly all implements that one desires to attach with a QH need to have toplink height altered.
/ iMatch Quick Hitch #25
I have several implements that just don't line up correctly. Works great on the ballast box, but the rear scraper, hitch yolk and the York rake will need some mods to work with it. Haven't checked the PTO chipper, or the auger yet.
/ iMatch Quick Hitch #26
I am in the same situation...I bought one years ago only to find out it did not work on everything...Have not used it since..
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Landpride PL3048 (A64126)
Landpride PL3048...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
