I'm the guy with the FX24D that failed in an hour
   / I'm the guy with the FX24D that failed in an hour #11
Re: I\'m the guy with the FX24D that failed in an hour
</font><font color="blueclass=small">( Greetings to all:
I am the one who bought the FX24D with "warrantee" which failed in less than an hour. I thought I'd clear up a couple of issues.
I've worked on and rebuilt many trucks, farm machines, motorcycles, mowers and so on but two different Yanmar dealers claim that this is a job that only should be attempted by a person with lots of Yanmar experience.
Dennis
Wichita KS )</font>
Dennis,
The fact that 2 Yanmar dealers told you that this should only be done by mechanics with lots of Yanmar experience is how they get you in the door for a transplant. If you can tear down trucks, motorcycles and just about anything else. You can surely do a transplant of a tractor engine. I also do all of my own repair work. I use to work as an auto/truck mechanic back from 1971-1980. I also can and have rebuilt motorcycles and whatever else needs to be fixed. I split my old ford 8N on 3 different occasion for rear end problems. How hard can it be to pop the hood off and pull the motor out of a Yanmar. My 7275 Cub looks like it would be a breeze to transplant once the loader and hood are off. Go for it and save your self a lot of money. Take pictures if need be if there are two many hoses and wires. Tagging the wires and lines will save you a lot of time if there are a lot of them on the motor. It can't be all that bad. One thing I would do is to pull the motor apart and see exactly what happened inside. Maybe the rings broke or stuck in the pistons. The fix would be much more reasonable if that is all that is wrond with it. Does the motor have liners in it? Check to see if they are scored. Any local deisel shop could pop out the old and put in the new if they are press fit. You could do them yourself if they are not press fit and seal with o-rings.
Good Luck,
Jim R.
   / I'm the guy with the FX24D that failed in an hour #12
I brought in an F46D with factory loader with 105 original hours. It was used at a tractor school in Japan for instruction. It even had a thick piece of plastic bolted under the cutting edge to keep it like new. Other than that, anything under 300 hours is unusual, with 500-800 being more common.
Back on subject, a fair mechanic can do a complete engine swap in a Yanmar in 8 hours or less, as long as there are not broken bolts or other issues. It shouldn't cost more than $500 labor. I wouldn't hesitate for an instant on a 900 hour engine as long as Ernie has fired it and it starts and runs well. I'd get it.
   / I'm the guy with the FX24D that failed in an hour #13
dude, did I miss something when I went to ebay and found the original transaction? The original ad said it was a refurbish tractor. Did it not? It also went on and on about the reconditioning process. When it comes to the part about the engine being rebuilt; it says (if needed). Take the dudes 30 day parts warranty aside and read the flashing rolling script on the bottom. He gauratees the tractor is as described. Well if it blew in one hour if prob needed the engine parts. I am confused on the 100 hr original part as I did not see that on ebay. If I were you I would save that ad on a cd now....... I wrote the dude you bought from. He said the engine was prob over reved. He said he rebuilds 2500 tractors a yr. He said this was the only engine failure.
I emailed you and got no response. I live in Kansas also. I bought a tx rebuilt yanmar. There is a used tractor dealer in
Big Springs kansas that can fix your tractor. Where in Kansas do you live? I am in the Topeka area. There is another guy from Topeka with a yanmar that knows a guy in Mayetta Kansas that can fix your tractor. It is not my business but I wish you well ........
<font color="blue"> </font> I guess Wichita Dennis would be from Wichita..... duh
   / I'm the guy with the FX24D that failed in an hour #14
I guess that's the dealer in Canton, Texas?
Mark must know these guys...
If they do 2500 tractors a year, you would think they would make this customer happy to save their reputation. Isn't that what customer service is all about?
   / I'm the guy with the FX24D that failed in an hour #15
Actually Mark, that photo was taken at the yard in Japan before containerization. I never got any photos of the tractor after it arrived, because it sold as soon as we pulled it from the container. There was no damage in loading, transit or unloading. It looked just like you see it in that photo. I attached another photo taken closer (also in Japan).
   / I'm the guy with the FX24D that failed in an hour #16
yup, canton. If you go to ebay and search completed items for fx24d you find the one with neg feedback..... I assume this is the tractor in ?
   / I'm the guy with the FX24D that failed in an hour #17
I've tried the search several times and came up empty.
Never mind.....I found it.
   / I'm the guy with the FX24D that failed in an hour #18
Me too. There are no results for FX24 or FX24D. In fact the only recent negative feedback for the Canton TX dealer was an F46 and I believe it was from September. How about an ebay item number?
   / I'm the guy with the FX24D that failed in an hour #19
Ok, I found this item #3822897430. However this is for a F46D not a fx24d? Maybe this happened twice. The seller of this one is guy who said "seems like the engine was over reved". I did not get the buyer to email me just the seller.
   / I'm the guy with the FX24D that failed in an hour #20
It appears that I confused an engine problem on a F46D WITH YOUR FX24D. I am sorry for any confusion. Did you purchase your tractor through ebay?
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2020 FREIGHTLINER M2 26FT STAKE BODY (A59575)
2020 FREIGHTLINER...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
