I'm screwed
   / I'm screwed #1
16valex
NY
bx23
Guys, I need some advise. I need to get a welder to repair my snow blower. Pictures are the result of my negligible attention.
What is your recommendation of proper amps welder I should get? I'm thinking of going to Harborfreight for an el cheapo.
Unless, someone here know of a good place where I can get it fix. I live in the Albany NY area.
Thank you very much.
   / I'm screwed #2
do you even know how to weld? if not, this might not be the best time to learn with all the snow falling. Do you have a welding repair shop nearby??
as far as good welders go, the term good welder and harbor freight cannot be written in same sentence.
spend a few dollars more and get a good 240 volt mig welder. this will give you a good range of metal thicknesses you can repair. Even a cheaper home depot version would be better than HF.
   / I'm screwed
Took a class 30 years ago. I'm one of those that usually not happy from any shop. I fix all my five cars and appliances and tractor.
However, I'm willing to hire a mobile welding service, I don't have any mean to bring my Kubota to a shop.
I thought China freight would be OK for once or twice of use then throw away.
I don't have 240V in my garage.
Do you think one of those 110V 90 amp from Chinafreight is OK?
   / I'm screwed #4
I agree: get a good MIG.
You'd be better off getting a $100 tombstone welder off of Craigslist than going to Harbor Freight.
I have a Harbor Freight welder and you can weld with it. It is just 10x harder to get a good weld. I also have a decent Hobart MIG and haven't used the HF welder since I got the Hobart.
I picked up my AC arc welder off Craigslist for $35 and it works fine. My Hobart was $700 new.
   / I'm screwed #5
If you don't have 240 I wouldn't try to repair this. You can do it on 120 but you need really good surface prep.
   / I'm screwed #7
Others have sound advice, however my opinion is a bit different. I bought the strongest 120V hobart mig I could buy at the time and it was 125ez. I put it on a 20 amp plug/circuit with nothing else on it and use it to fix/build stuff with. I am still in novice stage, but I am able to weld enough so it holds and I can fix stuff and build and move on. I agree to stay away from HF for welding machine, but it works in a pinch but its not the time to save money that way if you never welded in your life. I suggested to another TBN to try, and he never welded before. I think he is still struggling with welds and it keeps giving him cold beads on metal. I bought mine from local TSC store.
What I see on your blower - you will need to clamp the best you can where you want a tack weld and tack an inch worth ever 2-4 inches depending on the metal staying straight or not.
   / I'm screwed #8
If you'd live close to me, i'd come pick it up and weld it up for you. I wouldn't wast my money on a crap welder. If you dont have enough use to buy a good welder, your only good option is to rent or borrow a trailer and haul it to a shop.
   / I'm screwed #9
I would give similar advice; I like the portability of the 120V Lincoln-electric MIG I bought, I also use a dedicated 20 Amp circuit and I've no issues conducting typical repairs.
   / I'm screwed #10
you dont have to haul the tractor... you only have to haul the blower.
Even though i do alot of welding myself, i still take things to a great shop i know of when the works seemed far above my skillset. The last job i had farmed out was on a hydraulic fluid storage tank.... i didnt feel comfortable welding this tank, especially with some remaining hyd fluid in it. The shop straightened it out and welded and painted it for $78.00 . cant beat that with a stick.
as far as 120 volt migs are concerned... i have one. its a lincoln from h depot... i think i spent about $250 for it years ago. Is a fine machine for welding up to 1/8" on single pass. could probably do 1/4" ok...but i generally use my Hobart stick welder for that size or larger. What i really like about the 120v mig is fixing horse panels and other thin metal crap on the ranch. and getting 120 volts to it is a breeze.
40' High Cube Multi-Door Container (A50123)
40' High Cube...
2019 Nissan Sentra (A51694)
2019 Nissan Sentra...
DESK (A53843)
DESK (A53843)
2005 Fella-Werke SM-320 (A50123)
2005 Fella-Werke...
100' Roll of new 5/8"/16mm Crane Cable  (A52384)
100' Roll of new...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
