I'll sure miss this oak tree...
/ I'll sure miss this oak tree... #21
Wow! I wish you were close to me. I had them save some random pieces. It's really nice looking wood. Most all the rest went to a landfill. I inherited a lathe and planer but my woodworking knowledge is about nil.
Not everyone has woodworking skills...Why I mentioned an artisan...there are some really good craftsmen out there that don't charge an arm and a leg...
I like making beads on a lather...really hard wood can be polished like glass...
/ I'll sure miss this oak tree... #22
Trying to find a pic, but so far I can't. My Cousin made a wooden chip and salsa bowl combination out of one piece of wood. Very cool.
All I can do is ask dumb questions. They left some wood so I can make things out of it. They finished and it started raining, wood is getting wet. What should I do, put it under roof? How long before I can use it (season it's called?). How do I dry it...will it split?
I'm 70...made lots of things of wood my wife loves...but I now realize on a scale of 10 I'm maybe a 1.2.
Years ago I worked next door to a cabinet maker who had an amazing amount of equipment. All I could do was watch him work with my mouth hanging open.
/ I'll sure miss this oak tree... #26
The more the interior is open the faster it will dry...
If there is no chance of insects once the moisture content is 18% or less it should be fine...if there is a possibility of insects (you might not be able to see) internal temperature needs to reach 140* F...
Milling it with the grain will be less likely to twist or crack...
The key to drying is keeping it dry, warm (sunlight is good) and lots of air movement...turn it over every few days for even drying...
Here's the final cut, my phone ran out of storage at the end. Guy cutting is my age (70).
/ I'll sure miss this oak tree... #28
A 43 year old oak is 60" in diameter? 😲 What did you fertilize it with? Or did my pre-coffer brain not get 2 when adding 1+1?
/ I'll sure miss this oak tree... #29
+1, around here a 60" oak tree would be 300+ years old. I cut down a 40" hickory last year and stopped counting rings at 200, I easily had another 50 to go.
/ I'll sure miss this oak tree... #30
I guess it depends on where the measurement is taken?
I measure at the point where the log base starts, i.e., approximately where this tree was cut above the stump.
Some people measure at ground level.
A 43 year old oak is 60" in diameter? What did you fertilize it with? Or did my pre-coffer brain not get 2 when adding 1+1?
Growth rings are spaced wide...I counted about 50 so although very small planted it must have been a few years old.
Yes...ground level.
/ I'll sure miss this oak tree... #33
$1,500 to just drop it, $2,500 total cut & haul everything off, grind stump and grade it level. I started to rent a bucket truck but they had another truck with trailer & tractor. I'd still have to hire helpers. I thought price was OK. Plus they got two more jobs from neighbors seeing them work.
Price seems about right. I paid $2k last year to have a large elm taken down - used all 60' of his bucket truck. I did the cleanup (I burn for supplemental heat). I will need to call them back out, to grind the 48" stump. I will miss the afternoon shade on the house, but it was split and I'm real glad it didn't fall on my LP tank or pole barn.
Yes...ground level.
5ft at ground level. Some pieces I saved.
/ I'll sure miss this oak tree... #35
It is hard to imagine that much growth in 43 years even if he put in a large oak with a tree spade. Around here in the woods about 1/4 inch per year on the diameter is standard growth for an oak tree. In town with no competition perhaps a 1/3 inch or a bit more.
I really did not see much in the way of rot, perhaps the base got nixed in mowing and that was a "repair" by the tree. Certainly since it was close to the house and it gives you piece of mind good to remove it. I had a maple fall once and just clip my house and my father had 2 oak tops fall on his house and punch a holes in the garage roof.
He got 4 or 5 taken down for $1300 near the house (but this is Ohio). Just cutting them down, we had to remove all the wood and branches but the neighbors did that for the wood. The cutter did take one oak just for the wood. I thought it was a bargain for dad.
My neighbor in town had a 60 inch at the base oak taken down near his house. I got a slab to make a live edge table top. He paid either $3000 or $6000 as I recall. I will have to ask him for sure. It was a big project with a bucket truck etc. They also took out his stump for him.
If you could plant oaks and harvest them at that size in 43 years you could do great. I had 5000 red and white oaks planted in the early 90s and I think only about 500 or less survived. Most are 6 to 8 inches in diameter now, one near a cherry tree that gets little sun or water is only about 1.5 inches in diameter and 3 feet tall. The others may be 15 or 20 feet tall now. Good write up and photos.
/ I'll sure miss this oak tree... #36
We had a really nice oak in a really nice spot on our property with a big horizontal branch just right for a swing. So we built our cabin next to it. Then as we got the brush cleared out around it we realized that the tree was hollow. So 2 years later the tree was gone. The tree was not only close to the cabin, but the power company felt it was to close to the power lines and trimmed it a little. We had a logging company come in to harvest some of our pines, so as part of the contract they used their tree shear to cut it down so the direction of fall could be controlled. It was more hollow than we expected, there was only 2" of wood under the bark at the base of a 30" diameter oak.
As for the rate of growth of an oak, it depends on the environment. We planted a 1 yr live oak seedling from the forestry service and 25 yrs later it was 36" in diameter and well branched. It was planted near a pond so it had plenty of water and I fertilized it occasionally.
/ I'll sure miss this oak tree... #37
/ I'll sure miss this oak tree... #38
I have many large oak trees. Some are very symbolic to me and have been thru my whole life.
This picture was taken by my Aunt who was a Barnstormer Pilot in the 40s. This picture was taken in 1948. The year my parents bought this farm. To the right end of the pond dam you can see a young oak tree slightly leaning to the left. The lean got worse with age. I love this tree and it's diligence to overcome obstacle.
Here's a pic of the same tree, taken from the back side of the pond dam in 2014. Clearly it's "lean" got worse with age. I still loved this tree. One of my favorite large oak on my farm. In later years it got a wound on the side which caused rot in the core of the log.
Today my Son and I were burning our timber to control unwanted scrub brush. You need wind to burn a timber. Today was 25mph out of the West. After the fire burned past the oak I wet it down and soaked the interior that I could reach. I went back to the shop to refill my sprayer tank and when I returned the outcome was inevitable. The tree's outer layers and bark prevent you from infiltrating with water. So the decayed part of the inner core simmers and you can't put it out. I expect to go check on the tree in the morning and find it on the ground. This greatly saddens me. I place a value on these old oaks beyond money. This tree has been a part of my life since I was a child fishing in that pond.... :(
/ I'll sure miss this oak tree... #39
I used to be very sentimental about old oaks. They were witnesses to so much. But here, one would die, and we would mourn, then another, and we would mourn, then a dozen, then two dozen. It's sad to take a chainsaw to a 200yr old oak, but the sadness is now more like a sense of utility - all those that passed beneath it would want it put to something useful. It doesn't look like oak wilt has made it very far into Missouri, time will tell. In Wisconsin it's become common all over.
/ I'll sure miss this oak tree... #40
3TS That rate of growth is just amazing to me. I can only guess if they are that wide they may not get too tall. Some of my walnuts in the woods are nearly 40 feet to the first branch. That is a best guess, I did not climb up to measure them.
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
44" HYD MINI WOOD GRABBER BUCKET (A60430)
44" HYD MINI WOOD...
2008 VOLVO VHD64B CRANE TRUCK (A59905)
2008 VOLVO VHD64B...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2010 FORD F550 XL SUPER DUTY SERVICE TRUCK (A60430)
2010 FORD F550 XL...
