IH 784-which gear?
/ IH 784-which gear? #1
Rang
Terrell, TX
IH784
Can someone give me some guidance as to what gear I need to be using when I mow, disk, etc. My husband always did these things, but he has passed away and I do not have a clue which gear I should be using. Can anyone enlighten me?
Thanks so much.
/ IH 784-which gear? #2
Not knowing what the ground speed is for each gear for your tractor, it is hard to give you a quantifiable answer. I have several geared tractors and do the majority of my mowing and pulling in 1st gear. When I am moving from one area to another, then I shift into higher gears. I am also a bit more cautious (hesitant) than most people so I generally move a bit slower.
Sorry for your loss.
/ IH 784-which gear? #3
Underground.........fastwalkingspeed............ontop........a bit faster.........ALWAYS A SPEED YOUR ATEEZE WITH !
/ IH 784-which gear? #4
My suggestion is to find someone local that can spend a day with you guiding and going over the tractor including maintenance and driving. It may cost you $100 dollars or so but if it will keep you from burning the tractor up and running it safely you will be light years ahead. Just my $.02
Thanks for the advice guys, I'll see what I can find.
/ IH 784-which gear? #6
Low range third or forth is good for most chores.
/ IH 784-which gear? #8
I've got a 784, and I've always used low 3rd or 4th for slower work, and 1 high for disking. Dont forget you have the T/A on the dash to give you kind of an in between speed on ranges.
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
96" X 20' TRI-AXLE TRAILER (A64280)
96" X 20' TRI-AXLE...
1995 John Deere 7400 (A60462)
1995 John Deere...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Caterpillar Tool Manual (A63117)
Caterpillar Tool...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
