IH 784-which gear?
/ IH 784-which gear? #1
Rang
Terrell, TX
IH784
Can someone give me some guidance as to what gear I need to be using when I mow, disk, etc. My husband always did these things, but he has passed away and I do not have a clue which gear I should be using. Can anyone enlighten me?
Thanks so much.
/ IH 784-which gear? #2
Not knowing what the ground speed is for each gear for your tractor, it is hard to give you a quantifiable answer. I have several geared tractors and do the majority of my mowing and pulling in 1st gear. When I am moving from one area to another, then I shift into higher gears. I am also a bit more cautious (hesitant) than most people so I generally move a bit slower.
Sorry for your loss.
/ IH 784-which gear? #3
Underground.........fastwalkingspeed............ontop........a bit faster.........ALWAYS A SPEED YOUR ATEEZE WITH !
/ IH 784-which gear? #4
My suggestion is to find someone local that can spend a day with you guiding and going over the tractor including maintenance and driving. It may cost you $100 dollars or so but if it will keep you from burning the tractor up and running it safely you will be light years ahead. Just my $.02
Thanks for the advice guys, I'll see what I can find.
/ IH 784-which gear? #6
Low range third or forth is good for most chores.
/ IH 784-which gear? #8
I've got a 784, and I've always used low 3rd or 4th for slower work, and 1 high for disking. Dont forget you have the T/A on the dash to give you kind of an in between speed on ranges.
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
Hydraulic Bottle Jack (A61573)
Hydraulic Bottle...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
