IH 720 plow
   / IH 720 plow #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
Here's a pic of my "new" IH 720 plow, it's a 4 btm 18 in. Is a semimount, has side hill hitch, and auto spring loaded resets. I'm hoping to use it to tame my jungle. This plow has a high clearance so should be good hopefully in the thick sod and old corn stalks.
   / IH 720 plow #2
That's cool. Is the tractor yours as well?
   / IH 720 plow
Yes the tractor is mine. It has taken some getting used to because of its size but I like it. Couple things have surprised me about it; the power steering is extremely smooth and handles like a smaller tractor and the two rear remotes hook up very easy. I was expecting a battle when I hooked up the plow but it was not to be.
   / IH 720 plow #4
I think more pics are in order Oleozz. Sure, it's bigger than most of our tractors but we'd all like bigger if we could.
When I was a kid, I had a plastic model of an IH 1466 and a semi-mount plow like yours. Was a lot of fun to put together and I think I actually learned a thing or two about tractors by doing it.
Fun stuff!
   / IH 720 plow #5
I want to see it in the ground
   / IH 720 plow
Yes, I do to. Makes me a bit nervous thinking about the first time I use it, I am used to pulling a 2 bt plow and I have a feeling this will be a bit different.:)
   / IH 720 plow
Fun stuff!
There are a lot if IH guys who collect those models and some of them bring good money. Here is another pic of the tractor, had duals on when I bought it but duals and plowing don't go together.
   / IH 720 plow #8
Wow!! Nice rig. You'll be able to do some serious sod busting with your 1066/720 setup.
You're in another league compared to me. Only have 10 acres total, 7 acres pasture that I plan to make into a hayfield later this year.
Just got an IH #8 Little Genius 2-14 trailer plow (1940s vintage) to go with my MF-135. Plow cost $350, but shipping was twice that (darn $3.85/gal diesel).
Need to fix a low oil pressure problem on the 135 before I can play with that plow.
How much did you pay for that 4-bottom plow?
   / IH 720 plow #9
I am curious as to what you paid for it also. When I was plow shoping the International plows were expensive. I ended up buying a Massey Ferguson 880 5-16 plow for $127 with hydraulic resets. It was a base 4 bottom with a add on fifth. I had to unbolt the rear wheel assembly, unhook the hydrauilc lines, remove the fifth bottom and put the rear wheel assembly back on and hook up the hydraulics again. So now I have a 4-16 with the fifth bottom to rob parts off of if needed (so far I stole a pin off of it for the hydrualic reset cylinder).
I noticed a huge difference between my 3-14 and the 4-16 so I am sure you will love how fast you get things plowed going from your two bottom to a 4-18. It is a nice rig.
   / IH 720 plow #10
In contrary to what you said, you may want to put the dual on that rear left tire. It will help keep you from slipping as much. Atleast that's how we do things where I'm from, but those old IH plows especially the 720 and 735 were good plows.
-Funkster-
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
2011 Ford F-350 XL (A50120)
2011 Ford F-350 XL...
JCT 84" Rock Grapple (A50121)
JCT 84" Rock...
2013 Ram 4500 Versalift Bucket Truck (A50323)
2013 Ram 4500...
