IH 404 r&r governor
/ IH 404 r&r governor #1
johnfar
Henrico, VA
Craftsman LT5000
How do I remove and replace governor on my IH 404. It idles fine but if I advance the throttle any, the engine goes to wide open and stays there until I turn off the ignition.
/ IH 404 r&r governor #2
If it's what I think it is, you just need to remove the front cover. I'm guessing the governor spring has broken. Not a bad job to replace, just a little time.
First, remove the pin from the clevis, that goes to the carb. (#2) Then you can remove the cover. Should be about 5 bolts in it. Here is a link to Case/IH parts page. Official Case IH Online Parts Store and Case IH Catalog for Parts Search and Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts Open it in a minute, and look for part #10 on the exploded view. That is the spring more than likely broken, letting the engine race. While you're in there, might as well replace part #31. It is the thrust washer, that the gov. arm fork rides against.
If this happened all of a sudden, it's a good bet this is what it is. I always keep a spare spring, and T-bearing in the shop tool box, as I have 6 tractors that use the same parts.
The cover gasket normally comes off without damage, if you're careful. But, that would be up to you, if you want to replace it, while apart...
Thanks for the help, I'll let you know how it turns out. This is my first farm tractor.
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2013 JOHN DEERE S550 GRAIN COMBINE (A64277)
2013 JOHN DEERE...
F-450 SuperDuty Flat Bed 4WD (A63689)
F-450 SuperDuty...
VH4D Wisconsin Engine (A65640)
VH4D Wisconsin...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
