bytwnracer
- Joined
- May 7, 2024
- Messages
- 2
- Tractor
- Branson
I have a Branson F3550 with the Mitsubishi S4l2 diesel engine. I was having a problem with engine surging. I replaced the injectors and problem got worse so I took injection pump off and got it tested and was told it needed to be rebuilt by a very credible and reliable shop. Put rebuilt injection pump on and now when I start it it wants to run wide open. If I take off fuel shut off solenoid I can control rpms by controlling lever inside governor. I can get tractor to idle perfect and rev up perfect. Throttle arm outside of governor does nothing. But as soon as I release arm inside it wants to run wide open. What else can I look at? According to service manual governor is complete and correct. Any ideas?
