Idle Well
/ Idle Well #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
Do I have a good well or just a hole with water in it?
We have a board well that is 12" wide, if I remember right, and 70' deep. Every time I looked the water was about 12 feet from the top. But we haven't used it since 1998 when rural water became available. If there is still water in it, what are the chances that it still acts like a well? I took the pump and all the pipes out years ago. Now I am considering capping it permanently if it isn't worth using.
/ Idle Well #2
Maybe drop a pump suction hose in, pump some water out. Given the pump's capacity in GPM, and monitoring the water level in the well, that would give you an idea of the well's current recharge rate.
/ Idle Well #3
Since you took all the pipes and the pump out, you just have a hole with water. As stated by bumperm, pump some water out and see if it refills at a decent rate. As long as the recovery rate is acceptable, have a drinking water test performed. Chances are the well is fine, but standing water can be bad water. Make sure you pump a lot of water before having the tests performed. Some folk will tell you to dump chlorine and similar down the well to clean it, don't... If you are going to treat the water, treat it after it comes out of the ground and set up a proper chlorination and filtration system.
/ Idle Well
I'm looking to convert the term "chances" into a percentage. If it is just a 50/50 chance, I'll cap it and forget it. But if there is a 90 percent chance it is still a good well I just might rebuild the cover and stick in a hand pump.
/ Idle Well #5
I'd say it's likely above a 90% chance it's fine. Many well issues come from lack of use, put it to use and many issues clear themselves up.
/ Idle Well #6
it may be different in your county.. but in my county, if a well fails a test, procedure is to treat the well for 24 hours with chlorine, then after that elapsed time, run water for a couple hours, then retest. if it fails again, then you have a problem.
I agree.. a stagnant well is worse than one otherwise good and running.
I wouldn't be at all surprised if asked to treat a dormant well before use.
Lets face it, when they drill them they treat them, and then treat the plumbing before a co. ...
/ Idle Well #7
I wouldn't want to dring or use water for anything but irrigation ouit of a well that is used only occasionally and for short periods. Stagnant water goes bad.
However after putting in a pump and controller, your irrigation water will be almost free after the cost of electricity. Cheaper than city water for sure.
Harry K
/ Idle Well
Harry K
I've been thinking about that for a while now, and i am thinking i will put a new dog house over it, that is big and heavy enough that someone can't get into it without working at it. I hate to plug a well because you never know what is in the future.
Your right about the price of rural water. We pay $95 for 4000 gallons. That's just water, no sewer, no garbage or anything else added in.
/ Idle Well #9
Keep in mind you can only lift water 26 feet, from a pump on the surface. A two pipe system can double that. After that the pump needs to be in the well.
Does the well have a case? Outside pipe? They are usually only 5 or 6" around here.
/ Idle Well
It's a bell tile. I think it is 12" maybe it's only 10" on the inside, I haven't looked at it for a few years.
/ Idle Well #11
They make a hand pump that is really slick. Here is the site Hand Water Pump or Motorized, by SIMPLE PUMP A young couple over at goingslowly.com put one in and it worked fine before they had reliable power and works with a submersible in there as well. Best part is you can install it yourself. If you can see water 12 feet down, try and find a used submersible on Craigslist or a jet-pump on Craigslist to do some testing with. Even if it does run out of water after pumping for 10 min, if it recovers in 30 min you at least know you have water that refills and a smaller pump can be great for irrigation/garden/etc.
They also make a "pitless" adapters that will allow you to put the well cap at or even below ground level and the actual water line attaches a couple feet underground into the side of the casing. This will allow you to house any pressure tanks or hide the fact that a well is there by moving all well house stuff to another location.
I have a spare well on my property and I have thought about using it with a very small pump to drip water on my roof during these hot summer days to cool my temperature off. One day I may hook it up.
