Identifying Wiring Harness Connector....
/ Identifying Wiring Harness Connector.... #1
MicroPilot
Northern KY
Cub Cadet GT3500 hand-me-down
I want to add some aux lights on my tractor and want to feed them off the connector in the rear of the tractor thats to be used for trailer lights. Any ideas where I can find the proper male part of this plug? It's an 8 pole connector, kind of rectangle shaped. I'll post a better pic tomorrow, but here is one showing the location.
/ Identifying Wiring Harness Connector.... #2
I dont know, but I ran 2 #12 wires (fused 15A at the battery--get a fused lead assembly from Advance or Autozone), ran the wires (with 2 grounds to 20A illuminated toggle switches mounted in the plastic console under the factory light switch, which provides enough slope to keep rain and ice out of switches. Works great and lots of voltage and amps. One switch handles the forward rollbar lights and the other handles the rear backhoe lights. Only drawback is that the kids or an animal can trip the switch when the tractor isnt running.
/ Identifying Wiring Harness Connector.... #3
I just went through the same dilemma /forums/images/graemlins/confused.gif - even the dealer couldn't find the right male plug. My 3510 had a couple of "hot" wires in the harness under the rear fenders. As far as I can tell it is the same 20A circuit for the rear hazard/brake lights. I haven't had any problems related to overload since I put them into use a couple of months ago. I'm running two 55 watt (trapezoid) lights and haven't "popped" a fuse yet. The switch (lighted) is in the same place as "fbj2c"s set-up. Pics available.
/ Identifying Wiring Harness Connector.... #4
Did you try a specialty trailer shop? If it's a plug for a trailer, it's probably a standard trailer plug. I rewired my trailer a few months ago, and the local truck and trailer shop had about every type of electrical trailer connector you could imagine. I adapted the standard six pin connector on my Toyota to a standard four pin connector that comes on most trailers without brakes.
It's not really a trailer connector. It's meant to plug into the rear remote set's trailer connector, which I believe is a standard 6 conductor plug.
/ Identifying Wiring Harness Connector.... #6
MicroPilot,
Howdy! I am about to add some more lights to my 3035 and was wondering if you had made any progress on identifying this connector? I haven't spent too much time looking yet. I am thinking that it may be less time to pick up a standard connector and replace the existing one.
No, I never did identify this connector. I suspect that you would need to go through a parts manual to figure it out. I ended up just plugging into the connector using a "spade" plug I cut down to fit the connector. I'll try and remember to post some pics.
I basically did the same thing that SassafrassPete descibed in this thread:
ROPS Lights
/ Identifying Wiring Harness Connector.... #8
Micro,
I have a trailer connector with from the factory on mine. That looks like the connector that goes to the mutli pinned trailer plug.
That's exactly what it is.
I was hoping someone would know a part number or mfg of the matching male part of this plug so I could make my aux. light install a little tidier.
/ Identifying Wiring Harness Connector.... #10
Ok I get it...
I was just going to buy a trailer plug from wallymart and wire my rops lights into it. I'm so lazy.
I guess if you were so moved, you could by the part thats installed on my tractor and hack it just to get the plug.
probably not....eh
/ Identifying Wiring Harness Connector.... #11
My Century 3045 came with the dual remotes so it also has the electrical trailer light hookup so I have the male plug to this adapter. It was installed before shipping to the dealer.
Have you tried e-mailing century from their homepage to see if they can give your dealer the item number for it? When I had problems with the really short seatbelt I emailed them and had a response the next day.
Hope you find it.
/ Identifying Wiring Harness Connector.... #12
The Branson part number is "TZB9440000A3-Trailer Socket Assembly"
This is for a short harness that has the male plug you are talking about on one end and the 7 blade trailer socket on the other end. The part should be the same, but the Century number may be different.
Jerry
/ Identifying Wiring Harness Connector.... #13
I know this is an old thread and there is at least one other with the same question.
I think I might have stumbled on something today, check out (Google for) Pollack 11-933p.
No guaranty, I haven't looked really close, but I saw something VERY much like this on the back of a new McCormick a couple of weeks ago and nearly asked the dealer's parts guy to get me "that bit".
BTW, I first saw it listed as a Chrysler part and since I have a Dodge Durango I will probably squirm under there, trace back from the 7 pin trailer socket and see if I can pull out a short section that kinda/sorta looks like this.
Then see if it plugs into the back of the tractor.
Then explain to SWMBO (she who must be obeyed) why she can't pull a horse trailer for a few days (-:
2012 International Prostar (A63118)
2012 International...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
John Deere 5055E (A64126)
John Deere 5055E...
