Identify hydraulic pump
/ Identify hydraulic pump #1
earl6969
I have a Predator 425 backhoe. The hydraulic drive just quit and I found that the gerotor inside the hydraulic pump had broken. I cannot identify the pump company to attempt to order parts. The backhoe was made by Superstav in the Czech republic in 1997. The pump appears to be supplied by a company out of Italy. I wonder if another tag is missing with the company name on it. Anyone recognize the tag? Or is there a shop in the U.S. that can remake the gerotor. (I have enough pieces to get the dimensions) the tag says Axial Pump APVC-250. I can't figure out how to attach a photo.
/ Identify hydraulic pump #3
Is this pump a hydrostatic drive for the travel function? If yes it sounds like the charge pump is what failed. Italian could be Brevini.
/ Identify hydraulic pump #5
So the charge pump is the gerotor positive displacement pump inside the variable volume pump, correct?
/ Identify hydraulic pump #8
Scoda looks like like renamed Atos pumps.
Earl
Was there a piston pump with the geroter as second pump for another function like steering? Reason for asking is that the Scoda- Atos do not show a geroter pump option
/ Identify hydraulic pump #9
Earl
I’m curious of the same. A gerotor pump typically is lower pressure.
They are however used for “charge pumps” for piston type hydrostatic pump normally used for propel
Would be a really odd setup if it was used as an open circuit system like a backhoe to run differential area cylinders.
2008 28ft. Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 28ft. Regal...
2018 Ford Fusion Passenger Car, VIN # 3FA6P0HD6JR217606 (A61165)
2018 Ford Fusion...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
20ft Shipping Container (A61166)
20ft Shipping...
UNUSED PEANUT WAGON QUICK HITCH (A62131)
UNUSED PEANUT...
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
