Identify hydraulic pump
/ Identify hydraulic pump #1
earl6969
I have a Predator 425 backhoe. The hydraulic drive just quit and I found that the gerotor inside the hydraulic pump had broken. I cannot identify the pump company to attempt to order parts. The backhoe was made by Superstav in the Czech republic in 1997. The pump appears to be supplied by a company out of Italy. I wonder if another tag is missing with the company name on it. Anyone recognize the tag? Or is there a shop in the U.S. that can remake the gerotor. (I have enough pieces to get the dimensions) the tag says Axial Pump APVC-250. I can't figure out how to attach a photo.
/ Identify hydraulic pump #3
Is this pump a hydrostatic drive for the travel function? If yes it sounds like the charge pump is what failed. Italian could be Brevini.
/ Identify hydraulic pump #5
So the charge pump is the gerotor positive displacement pump inside the variable volume pump, correct?
/ Identify hydraulic pump #8
Scoda looks like like renamed Atos pumps.
Earl
Was there a piston pump with the geroter as second pump for another function like steering? Reason for asking is that the Scoda- Atos do not show a geroter pump option
/ Identify hydraulic pump #9
Earl
I’m curious of the same. A gerotor pump typically is lower pressure.
They are however used for “charge pumps” for piston type hydrostatic pump normally used for propel
Would be a really odd setup if it was used as an open circuit system like a backhoe to run differential area cylinders.
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2011 CARGO CRAFT PUMP CONTROL TRAILER (A67714)
2011 CARGO CRAFT...
2014 GULF STREAM TRAILMASTER (A67714)
2014 GULF STREAM...
2015 COTTRELL CAR HAULER (A67714)
2015 COTTRELL CAR...
12IN CENTRIFUGAL PUMP (A67714)
12IN CENTRIFUGAL...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
