ID this old Case tractor
/ ID this old Case tractor #1
vpd66
central wisconsin
Case 411b tractor, Dig-it backhoe, John Deere 318 tractor
I bought this tractor this weekend. It needs some TLC but overall seems to be in working order. The guy I bought it from says he thought it was 1958 Case 400B. I looked all over the tractor and I can't find any serial or model numbers on it. It has a gas 4 cylinder engine 4 speed trans with high and low range and a lever to the right of the steering wheel/dash that the guy I bought it from says its for the "Caseomatic". Not sure how it operates but the tractor seems to shift in all gears and drives fine. The tractor has a Eagle hitch and the frontend loader seems to be factory Case and you can still see the Case decal on it. I need a postive ID on this tractor so I can do some TLC to it (Carb kit, ingition parts, brake work, and etc).
/ ID this old Case tractor #6
I bet it's actually a 410B.
/ ID this old Case tractor #7
I would guess a 411b ?? All the pictures I've seen show the tag on the other side just below the throttle. Got any more pictures ?
I don't have anymore pictures, but could take any angle you'd like. The tractor is sitting in my driveway. I'm starting to think it isn't a 400b. The guy I bought it from said it was a 400b or 410. Everything I find on a 400b doesn't seem right.
This is getting even more interesting. I did some searching on the internet and I think it is a 411B. I found one website that said the 410B was a utility and the 411B was a row crop tractor. I took a closer look at my tractor today and I don't believe the decals are correct. I can see a new style Case sticker on the front of the hood. I've never seen one with decals like mine. Most have a "Caseomatic" decal where mine says Case. There is also a used equipment dealer sticker on each side, so hard telling how they dolled it up. I need to get this running better and I'm starting with a carb rebuild. Since I'm not 100% positive what model the tractor is, I took the numbers off the carb. It is a Marvel Scheber TSX 749. I never thought it would be this hard to ID a tractor from a company that is still in business. Not much info or pictures of these vintage Case tractor on the internet.
/ ID this old Case tractor #12
This sounds like a job for the Yesterday's Tractors group. Have you asked over there?
Ok, a little follow up. I received my copy of a I&T C-201 Case/International service manual. It seems there are quite a few different styles of the 400 series tractors. By process of elimination by looking at engine/transmission combos and front axle styles I have come to the conclusion that it is a 411B. I still don't know the exact year, but it has to be 1958-9.
/ ID this old Case tractor #16
I am no expert but I was thinking early 60's on that tractor. Had an older Case SC and a 1370, both were good tractors.
I have the cylinder head off now and it has G148 cast in it. From what I read, G148 was used in the 50s and G148B was used in the 60s. Someone did a really bad valve job on it (no margin left on half the valves) and I only had 60psi of compression in one cylinder. I ordered new valves, guides, and a gasket kit. Should run much better.
The engine is back together and purrs like a kitten. Now I have to take care of some oil leaks then give it a coat of paint.
2003 Ford Mustang Coupe (A66738)
2003 Ford Mustang...
PORTA POTTY (A67714)
17601CFL (A61572)
17601CFL (A61572)
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2019 Nissan Sentra Sedan (A66738)
2019 Nissan Sentra...
