I swore I wouldn't do it ...
/ I swore I wouldn't do it ... #41
Nice ! I wish, but just bought a new tractor, oh well, one toy at a time ! Congrats and enjoy !
Rich
/ I swore I wouldn't do it ... #42
I dunno..... one of my employees had a brand new Tundra, and it was in the shop 5 times in the first 3 months.
Hope your luck is better
I have had it for 5 years and not even a hiccup.
Do you realize that Toyota trucks have more American made parts then Chevy, Ford, or Dodge?
10K GVWR ... 3.73 gears ... my driving has been local short runs and the computer says avg 14.6 mpg. Friday I have to haul a mule 200 miles north and will be pulling a 20' stock trailer. I'll see then.
Friday I took the stock trailer(GN) with two 1200 lb horses and one 1000 lb mule .... fuel economy gauge stated an average of 9.4 MPG...now I need someone to talk to me about the following. I mashed the tow/haul button and it sure is not like the Dodge ... seemed like it had no effect ... alot of automatic shifting from 4th to 6th just didn't feel right. I tryed the manual feature and sure didn't care for that. I thought the tow/haul kept it shifted down ????
Interested , but confused is SS for stainless steel or those big black pieces that go over wheel wheels on fender and 1/4 panels ?
Have the 3.55 gear r/e in mine gettin 18.9 city/ almost 22 hwy. Could not give any towing figueres never towed anything with it yet. Mileage report with 2/3 big men in truck at any given time(over 200 lbs each-:(),with tools,ropeing saddles/tack :D, and some field equipment in back. Taking off from complete stops easy,keeping hwy speeds 55 to 70. Also run it in 4wd daily so I don't get stuck or tear up back field.
Boone
Yes SS is stainless steel... they are sharp. I'll have to shoot a picture.
/ I swore I wouldn't do it ... #45
I can relate to how the tow/haul works with the Ford Superduty diesel and it should act the same with a gas engine truck. Using tow/haul changes your shift points so that the transmission shifts at a higher rpm. It also will downshift the transmission as you're applying the brakes and works with your integrated brake controller. I've had it on two Superdutys and it's one of the best features on these trucks.
I did notice the downshift of the transmission. Towing the trailer it appeared to shift alot ... seemed as if the transmission was doing nothing but shifting. I would be going along at 75mph and the slighest condition that required some power it would shift down to 5th and then to 4th and back up to 5th and then to sixth and back down ... I kept thinking this can't be good on the transmission.
/ I swore I wouldn't do it ... #47
Blue,
NICE TRUCK Sir! :thumbsup:
My old F-150 is white I put a USA Flag bug shield on it and it really made it stand out... Very sweet ride.
But I'm a hard core Ford guy too! I'm still looking for my new (used) truck...
Be well,
David
/ I swore I wouldn't do it ... #48
Great looking truck!! Blue, your pretty White truck is making me Green.
Charlie
/ I swore I wouldn't do it ... #49
That is a gem...
I plan on getting a new one when I retire...
But...
I can't afford to retire...lol
/ I swore I wouldn't do it ... #50
Its not good for it at all... Just generates heat and acellerates wear. Not to metion killing fuel mileage in the process. Truck is probably in need of more gear to help it overcome the loads being applied to it. Or you can lock it out of 6th when pulling.
Blue,
Be well,
David
Thanks David ... last new Ford I had was in 1999 experienced some difficulties and that then became the year I got my first Dodge ... I can not say enough good about Dodge. Am hoping my Ford experience is a good one.
I thought that "tow/haul" was supposed to do that. I quess the manual shift will be the way to pull with it.
Charlie
Thanks Charlie ... hope all is well ... Maybe 2 aspirin and a good nights sleep will cure the "green" .. if not I think the dealership has more white trucks !!!!!!!!!!!!!
That is a gem...
But...
And ... if you do retire I'm told one gets busier than when they are working .... I don't need to have more to do So I'm just gonna keep working!!!
/ I swore I wouldn't do it ... #55
Blueriver - The frequent shifting in tow/haul mode might be related to your low tow weight. For that <6K lbs you might be better off just using the standard transmission settings...just a thought......nice truck....My truck envy is almost as bad as my tractor envy... er... needs...Cheers, Gary
/ I swore I wouldn't do it ... #56
My Nissan Titan does not recommend using Tow Haul mode until the trailer weight exceeds the GVWR of the truck. So about 6,500# or less no Tow Haul, but from 6,500# to its max 9,500# use it.
Chris
/ I swore I wouldn't do it ... #57
I'd say its hunting gears because of the trailer catching a lot of wind. To get the load moving, its the weight of the trailer that makes a difference, but once its moving, its more about how much wind it catches. At 75 mph, wind resistance is a huge factor. If I remember some of my college classes, wind resistance is based on the square of the speed, so the wind resistance between 20 mph and 60 mph is not 3 times, but 9 times more.
/ I swore I wouldn't do it ... #58
Nice rig Sir,this is one old Aussie true blue Ford man that is green as well, would like a new F series but She Who MUST be obeyed keeps saying a definate NO, same with a new tractor:(. As for retiring being busier than when I was working, YES Sir you are busier than ever:laughing: I was told by a friend that retired people never have any spare time as they are always too busy, and yessir she was right.
/ I swore I wouldn't do it ... #59
Congratulations. You will absolutely love it! I have a 2011 2wd with the 6.2.
Low maintenance costs are awesome. I use the mobil 1 ep 5w20 change oil every ten thousand miles myself and am currently at 40,000 miles with no issues at all. average 18mpg highway and 14 city.
Unfortunately only average 8 when pulling this 12000lb beast down the interstate.
/ I swore I wouldn't do it ... #60
Welcome back to a gas engine. I sold my 07 Dodge 2500 CTD and went to a Tundra. It had plenty of power but it drove me crazy shifing on the interstate between 5th and 6th. I had another kid so I looked for a truck with a bigger cab than the Tundra dbl cab. I test drove the GM 6.0 and the Ford 6.2 gas and the shifting aggravated me to no end going up the mountains on I-81. I don't think there is anything wrong with your truck it's just you went fron 600lb of torque back to the 400lb range. I now have a 2011 Ford F 250 6.7 XLT and really love it so far. I just got back from a hunting trip in Ontario and I averaged 21.2 mpg going up and 19.8 coming back on a 2,200 mile round trip. One of the riders in my truck had no experience with a diesel and he commented about how my truck never downshifted on the interstate. In my opinion the 6.2 Ford gas engine felt like it had more power than the GM 6.0. I belive you are still comparing a diesel to a gas and it just isn't the same when it comes to having a truck not having to downshift to keep the engine in the proper power range. Good luck and you have a nice ride.
2012 VOLVO ROAD TRACTOR (A64280)
2012 VOLVO ROAD...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
Caterpillar 330/330L Excavator Service and Parts Manuals (A63117)
Caterpillar...
