I started my backhoe Root Ripper.
/ I started my backhoe Root Ripper.
I added a double valve in the hydraulic circuit, in between the loader valve and the backhoe. One valve controls the thumb, the other controls the grapple.
I would like more info also. Do you know how much just the hydraulic part cost?
/ I started my backhoe Root Ripper. #62
It was a while back, can't recall the costs and probably more now anyway. I used a Prince stack valve from Surplus Center. I have since used a Bucher stack valve from Trausch for another application, it is a nicer and more compact valve. It would be easier to fit into limited space.
In addition to the valve, the hoses and fittings add considerably to the cost.
I did a write up on the thumb at the time, it includes pics and details on mounting the valve and running hoses.
I've used this setup a lot for years now, no issues of any kind.
https://www.tractorbynet.com/forums/kubota-owning-operating/323442-b21-backhoe-thumb.html
Thanks. Nice job on the thumb the post it great.
/ I started my backhoe Root Ripper. #64
16" for digging bigger holes and backfilling where FEL can not get.
I probably have most what I would need to make another bucket but I would have to but bucket teeth and those are not cheap.
If you are thinking of using it for backfill rather than digging, how about making a smooth edge grading bucket? Then you don't need teeth, either.
I want it for digging. I have an older horse at some point I will need to dig a very big hole for.
A while back I dug a hole for our other horse with an old woods 650 that had a 16” bucket. It still took me a while to dig it.
I could not imagine doing that job with a 10” bucket. You never know when I will need to do that job. I will have the bigger bucket ready.
I saw someone on here that made a 24” ditch and back fill bucket with no teeth that was pretty sweet.
My big debate was if I needed a third bucket one between 10" and 16". Today I am thinking that 10" and 16" is enough to do what I need.
I will wait until I see how well my 16" bucket digs and decide form there.
/ I started my backhoe Root Ripper. #66
My 580B came with a 24" bucket; I built a 6" "ditching bucket" using 6" channel for a spine, made it long enough so I could get 3' deep without the dipper tryin' to widen the ditch to 12" (sorry, no pics ATM) -
Tthen I lucked out on CL, found a 4' wide loader bucket - it's sitting there til I find that round "tuit", at which time I'll trace out the ends and plasma cut a couple more ends, then cut the 4' into a 1' and 3', or (more likely) a 16" and a 32", both of which will have smooth mouths;
the 16" will be mainly for digging footer trench, but I might make a pin-on tooth bar for it (clay soil, yuk) - The 32" will be mainly a grading bucket.
Your QA helped keep those projects in my mind :D ... Steve
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
Brake Drums (A62613)
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
