Ok fella's. The water well at the farm house needs attention. Besides the obvious leaky faucet and stool that needs attention the well is cycling about every 15 seconds. On for a few seconds and then off for 15. Give me some ideas, please. Pressure tank? It's old. I replaced the pump last year. I guess I need to check the pressure in the tank?.....Let the help begin!
Thanks,
Jay
Good Afternoon Jay,
I think your pump may be damaged.
If there is no water running and the pump continues to cycle on and off, the overload protector inside the pump is whats responsible for kicking the unit on and off. Once the pump pressure reaches the point where the pressure switch, located at the bottom of your pressure tank, has reached maximum pressure it shouldnt cycle anymore at that point !
You can test this theory my checking how many amps the pump is drawing, measured at the pressure switch. I dont think it should be drawing more than 6 amps, if its drawing more, then this is whats kicking the overload on the pump. Once the puimp cools back down, then the pump will start again...
I would check this first. Its an easy check !
Other potential problems,
bad bladder tank as others have mentioned
could be a slight break in the line from the well to the house.
potentially bad pressure switch. I doubt it...
Keep us updated !
BTW Im talking about an in well pump... submersible pump
