I need some track advice...
/ I need some track advice... #1
cmuncy
Willis, Texas
FarmTrac 300DTC
Looks like my Komatsu D21-P6 needs some undercarriage work.
Looking at the tracks ( wide swamp tracks that is) , it appears that the pins are worn clear through to the link pins, the drive sprockets need to be built up or replaced, and the rollers probably need to be replaced as well.
Other than that, at 4400 hours, the dozer is fine.
My question is: do I need to look at getting the tracks replaced or just repaired, and can I switch from the wide swamp trakcs to more traditional grouser tracks ( I need the added traction)
Any ballpark ideas as far as cost to havethis done would be appreciated as well.
Chris
/ I need some track advice... #2
You deffinetly need pins and bushings and sprokets unless they have a sproket liner kit available. the pads can be changed over for about 950 to 1200 back to dirt pads. Your rails probably need to be replaced but if theres an undercarriage shop nearby you might frind they will build them up or have a track machine that builds them up. Usually sprokets can be builtup but tehy have to be built up to a template. I have done them that way. You might can order a sprocket ring to. If you build your rollers up when the weld cools it will shink and kill the bearings. Ive aken the rollers abpart and built them up and then reboredthem on the lathe back to their bearing size.
/ I need some track advice... #3
Hello Chris,
What you can do if your rail height is still good is have new pins and bushings put in your chains. If not then new are in order and they are roughly $1900 for the pair. You can then have 20" regular grouser ($1700)put on or even I have put 13" pads ($1,000) on a "P" model. It's all a matter of preference. Sprockets can be fitted with new rims (cut and welded on) or just replace the whole sprockets ($600). If you need any help shoot me an email. Have a great one.
Darin
/ I need some track advice... #4
While you're at it, may as well check the idlers for wear and for bearing slop.
I pulled the tracks off of my IH500 which is about the same size and changed a few rollers and rebuilt an idler bearing but the rest was fine. No need to replace the round rollers or idlers unless they are worn below spec. If you rebush the rails, then new sprockets would be appropriate.
/ I need some track advice... #5
I would not try to replace the pin & bushings in those small rails I have worked as a field mechanic for a equipment dealer in pa for the last 33 years & we have found that new pins & bushings will not stay tight in those small rails once they have been changed
/ I need some track advice... #6
Sorry to interupt... but is the same cmuncy from TDS forums?
Thanks guys for all the responses.
Looksl iek I will aim for getting new grouser tracks for the added traction, r/r the sprockets, and replace the rollers. I do not know the status of the guide rail.
Now all I have to do is find a shop to perform this work.
and yes, I am one and the same cmuncy on TDS /forums/images/graemlins/grin.gif
/ I need some track advice... #8
I have R&R'd sprockets, rollers, idlers, and tracks in my backyard from my 10,000 lb dozer. A decent breaker bar, a come-along, and good set of sockets is all you should need. Mechanics that work on the yellow iron are not cheap and there is nothing on that undercarriage that won't fit in your pickup.
/ I need some track advice... #9
</font><font color="blue" class="small">( ...and yes, I am one and the same cmuncy on TDS /forums/images/graemlins/grin.gif )</font>
Small world this internet thingie ain't it? /forums/images/graemlins/laugh.gif
</font><font color="blue" class="small">( I have R&R'd sprockets, rollers, idlers, and tracks in my backyard from my 10,000 lb dozer. A decent breaker bar, a come-along, and good set of sockets is all you should need. Mechanics that work on the yellow iron are not cheap and there is nothing on that undercarriage that won't fit in your pickup. )</font>
I guess what I need to do is get the pressure washer out, get a clean area to work in, jack the frame up and yank the tracks off.
I guess the intimidating item here is pushing the pin out for the master link. I keep hearing that you need a 30 ton portable press to do it. /forums/images/graemlins/shocked.gif
/ I need some track advice... #11
On the IH, I had to push out a roll pin from one side of the master link pin then rotate the track until the pin was at the rear of the sprocket. Then I used a floor jack to push up on the track at the rear most part of the sprocket, effectively unloading the tension from the master link pin. Then use a sledge hammer and a drift to knock the pin from the outside to the inside. I went ahead and drove the pin all the way out and since the track is on the sprocket it stays put hooked on the teeth.
That is the trickiest part. All this undercarriage is pretty heavy and the tracks are not something to lift by hand. It takes some thought and some leverage to do most anything down there safely. The hardest part of the whole thing for me was positioning the rollers up inside the track frame so that the retaining bolts could be installed.
A good pressure washing before I started was very necessary.
I guess I am a bit intimidated of removing the pin in the master link. Everything else looks straight forward, or appears that way. I guess I can set the dozer on blocks and position the track to remove the pin. If I have dificulty, just put everything back together and send it to the dozer doctor.
I do have a complete service manual for it ( rewritten in engrish of course) so I have a good place to start.
I just had a thought...
I've got a large bore cylinder laying around. I could probably rig up a fixture to push the pin out using my Farm Trac's hydraulics.
Just an idea I had over lunch.
/ I need some track advice... #14
You probably already know this, set the dozer on wooden blocks, not concrete. The weight of the dozer will crush a concrete block.
/ I need some track advice... #15
I guess I am lucky to have the rear rippers. It meant I could lift the whole machine off the ground and rotate the track if needed or block up the one side so that I could remove the track without the machine running.
With the thing still on the ground and the pin on the sprocket, give it a tap if that's how you are supposed to remove the pin. Mine came out pretty easily. In fact, I ended up adding material with the welder and grinder to make the pin cylindrical. It seems that the bushing had worn it a bit.
As far as concrete vs. wood. I am pretty sure that an adequate concrete block could take it. We're not talking about a 30,000 lb dozer here. I used wood rounds for the lifting and 6 ton jack stands for the blocking. I kid you not, stout car stuff.
Give it a try, worst case is that you can't get the pin out. Some of the pins are pressed in and some owners have been known to weld these kinds of things in place if they get loose in the field.
/ I need some track advice... #16
I guess it depends on what kind of concrete block you are talking about. The "cinder block" or construction block will collapse under the weight of an automobile. Been there first hand to help remove the injured and or bodies from under cars and trucks propped up with cement blocks. A solid block will take a lot more weight, but will fracture easily if the weight is concentrated on a small part of the block (this is how stone masons shape granite). I have Mr. Murphy always looking over my shoulder, so I have to err on the side of caution to make up for being a klutz. Back to your statement "We're not talking about a 30,000 lb dozer here". No we are not, but a 10,000 dozer with the weight concentrated on a small spot on a cement block, is asking for trouble.
/ I need some track advice... #17
Safety first. 10,000 lbs is plenty to squish you, but not even twice what my 1/2 ton pickup weighs. When these things fall, they fall real quickly and quietly before the thud.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2015 Chrysler Town & Country Van (A61569)
2015 Chrysler Town...
2844 (A58376)
2844 (A58376)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
2017 JOHN DEERE 350G LC EXCAVATOR (A62129)
2017 JOHN DEERE...
2014 18ft. Parker Performance T/A Trash Trailer (A60352)
2014 18ft. Parker...
