I need a new mailbox
/ I need a new mailbox #1
Redneck_Randy
Platinum Member
Oklahoma
2005 New Holland TC35A
My current mailbox is plastic and I'm tired of my mail being water soaked after a rain storm. Not sure where the water is getting in so I'm just going to replace it. Do any of you have suggestions as to a good water tight mailbox maybe a locking version?
Thanks
Randy
/ I need a new mailbox #2
I would not worry about it. The Post Office will probably be out of business like everything else in this country soon or the mail delivery will be out sourced and they will want a special type of mailbox!
/ I need a new mailbox #3
We just replaced our broken metal mailbox with one of these from Rubbermaid.
Hamilton Mailbox | Rubbermaid
It was only $13.00 at Lowe's. We've had it for about a month and we have had rain about every other day and no wet mail so far. :thumbsup:
/ I need a new mailbox #4
I use to sell these, still have a few but shipping will kill you as they weigh about 70lbs. You can get them unpainted or painted, we even offered power coating.
Might find a dealer in your area. Mine has been up for years, no leaks
Good luck
/ I need a new mailbox #5
Moss...We bought ours at Lowes as well. It was similar to yours except it came with a plastic fiber post as well and it has been out there for 5 yrs. with no problems. There is a door on the backside of the mailbox as well so you don't have to go out to the street and open the front and it also has a slot below the mailbox for a newpaper delivery.
We bought this on since we are on a rural road and did not know if we would have a vandalisim problem with kids trying to destroy the mailbox from their cars with a bat and also to eliminate maintenace on the metal ones. So far no one has struck it with a bat or if they did it had no affect. I reccomend ours or yours over metal.
Thanks all !
Randy
/ I need a new mailbox #7
These are $50 at TSC. They're indestructible and don't leak.
/ I need a new mailbox #8
i got the big metal one and my mail dosent get wet only when the carrier gets it wet. any new one will work. I think mine is probly at least 10 years old, was here when i moved in 2 years ago.
/ I need a new mailbox #9
Here's my best mailbox tip. When you install the mailbox on the post, put the front lip down 1" below the back of the box. That way, if the door leaks, the water runs right back out instead of flowing through the box to the back. Of course, if the back of the box leaks. . .well, you know.:D
/ I need a new mailbox #10
if the back leaks get som clear silicone or the color of the box and fix it. Good tip though!!
/ I need a new mailbox #11
Our neighbor has one of those boxes with the door on the back, too. Every once in a while I am picking his mail off my lawn, as sometimes the carrier pushes larger stuff in through the front and pops the back door open. :confused2:
/ I need a new mailbox #12
jinman's advice about a slight tilt to the front is very good.
A second thing is to mount a piece of 1 x 6, 1 x 8, whatever fits inside the mailbox flat on the bottom of the mailbox. Leaks typically run down and puddle on the floor of the mailbox. The board keeps your mail up and out of the water.
