I Made a Mistake Maybe?
/ I Made a Mistake Maybe? #1
ppak
Dayton, OH
Cub Cadet LGTX 1054
I recently got a 2011-12 Cub Cadet SLTX 1054 at an auction. It only had 110 service hours. First try at my 2.5 acre lawn did not go well. I have a very mild grade slope and the tractor would not be able to climb the hill - so I turned and cut cross ways and it seemed to be OK. I have a transmission issue it seems, it is a hydrostatic. So I have a new problem.
Any help?
I wish! I can get the tractor to ease forward by literally grabbing the wheels like a wheelchair.
/ I Made a Mistake Maybe? #4
Any help?
Well, we are not sure.. but if the transmission is the Tuff Torque K46 which is a non serviceable model.. then you will want to read this thread.
http://www.tractorbynet.com/forums/parts-repairs/164892-tufftorq-k46-repair-guide-pictures.html
/ I Made a Mistake Maybe? #5
When you bought it did it come with any service records? Do you know if the hydrostatic fluid and filter were ever changed? Just a possibility. Hopefully you didn't get taken buying one with a problematic K46.
/ I Made a Mistake Maybe? #6
/ I Made a Mistake Maybe? #7
If it is the dreaded K46, there is no way to change the fluid, and there is no filter.. That is the problem. A self destructing grenade. The hours are about right for the problem to start showing up.
/ I Made a Mistake Maybe? #8
I didn't read all of the posts to the link you provided so wasn't aware. Seems kinda dumb not to have any way to change the fluid. Thanks for that info James.
/ I Made a Mistake Maybe? #9
Yep, and you want to hear the funny part?.. I have one of the things!:eek:
"No service neccessary" (or possible)
/ I Made a Mistake Maybe? #10
Drill a hole at the bottom. Thread and put in a plug. Drill a hole at the top. Refill with cheap stuff. Run and drain. Repeat. Put in good stuf. Try it out.
larry
