I have a case 90xt
/ I have a case 90xt #1
johntini
shelby twp michigan
case90XT
It seems to be losing its Prime. I have already replaced both fuel filters, still having Problems starting. What do You recommend?
/ I have a case 90xt #2
I am working through similar problems with my Turfcat.... I have been told to check all the injectors and lines for tightness, and any fuel line (rubber) for cracks or wear. Maybe one of these will help. Good luck.
/ I have a case 90xt #3
I own a 90XT also. The fuel shutoff uses an electric solenoid that I have had go bad before. It could be going out. I also found a very small leak in the fuel hose from the tank to the fuel pump. I was very lucky to find it because it was lightly misting fuel toward the exhaust manifold. We had to remove the oil cooler and radiator just to replace the rubber fuel line.
Good Luck
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A59914)
2025 DELCO T/A...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
International 490 Disc (A65640)
International 490...
