I have a case 90xt
/ I have a case 90xt #1
johntini
shelby twp michigan
case90XT
It seems to be losing its Prime. I have already replaced both fuel filters, still having Problems starting. What do You recommend?
/ I have a case 90xt #2
I am working through similar problems with my Turfcat.... I have been told to check all the injectors and lines for tightness, and any fuel line (rubber) for cracks or wear. Maybe one of these will help. Good luck.
/ I have a case 90xt #3
I own a 90XT also. The fuel shutoff uses an electric solenoid that I have had go bad before. It could be going out. I also found a very small leak in the fuel hose from the tank to the fuel pump. I was very lucky to find it because it was lightly misting fuel toward the exhaust manifold. We had to remove the oil cooler and radiator just to replace the rubber fuel line.
Good Luck
2007 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2007 Allmand...
2022 EZ-GO ELITE...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
