Stimw
Elite Member
I changed the battery in my 3510 today. It was cranking a little slow. I bought the tractor new in 2005 so the battery only lasted 8 years! Doesn't anything last anymore???
Now the complaints.
For starters the Owners/Repair Manual does not give battery group. All it says is 12V.
The markings on the battery are pointed toward the radiator so you can't see them.
You have to take the nose body piece off which is tight with a front bumper.
You have to take the air cleaner completely off which is a PITA.
I measured the old battery and came up with a group 33. I went to TS and the closest they had to the measurements was a group 31.
I bought the 31 Comercial made by Exide (very good batteries) for $99. plus the fees.
The new battery fit BUT was 1/4" taller so the top hold down didn't fit. I had to drill the holes out on the bracket and could not use the rubber piece.
I have my own business and am used to estimating repair times. I would put the time between 1 and 2 hours depending on if you had replaced one before.
Now the complaints.
