I can't wait for a snow storm!!!
   / I can't wait for a snow storm!!!
Finally had a decent storm to try it out. Here is a short video of me cleaning out in front of my wood pile. :thumbsup:
   / I can't wait for a snow storm!!! #22
In the up position, that blower sure is close to the ground?
That is something I noticed about mine too. My x534 uses the hydraulic lift same as it does for the mower deck. It has enough power to lift the blower, just not enough travel to raise it very high. I played with the adjustment on mine this year when I hooked it up and I could not get it to raise the bottom of the blower more than 5 inches. I'd like to see more but its not possible from what I can see, at least in a stock configuration.
   / I can't wait for a snow storm!!! #23
hows this for lift :) :D :D
im so rotten...aint I
   / I can't wait for a snow storm!!! #24
Not sure quite why you need it to lift more, but the reason it can't is probably because the blower drivetrain can't be made to move over that wide a range. I don't know exactly how the PTO to the blower connection works on X5xx tractors, but if there is a U-joint involved they can only handle so far off-axis. That's certainly the case on my 455 - raise the blower too far and it gets very noisy and clearly is putting a lot of stress on things.
Tim
   / I can't wait for a snow storm!!! #25
I picked up the 47 inch for my x534, I love it. I've only used it twice so far but just what an improvement over a regular blower or the shovel. Here is a picture of my baby.
   / I can't wait for a snow storm!!! #26
Tim
The reason for more lift would be to make it easier to transition from the street to the driveway. I don't have the PTO engaged, but with the limited lift the front of the snowblower drags the curb when I come up the drive from the street, either straight on or at an angle makes no difference. You can't operate the snowblower when its raised because its belt driven and the offset between the pulleys when its raised will throw the belt, at least that's what happens on mine.
I'd like to build a blade to fit the quick attach for the snowblower. Even with manual angling it would be nice to be able to mount a blade quickly. I should have kept the blade from my old JD lawn tractor and made an adapter to mount it on the X534.
   / I can't wait for a snow storm!!! #27
What are the 47 in blowes selling for?
2025 LandHonor DH-22-72W 84in Disc Harrow Tractor Attachment (A49462)
2025 LandHonor...
2011 Cadillac SRX SUV (A50324)
2011 Cadillac SRX...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2024 RP-12-72W 72in Hydraulic Power Rake (A49462)
2024 RP-12-72W...
