I am having a problem with my ROPS
/ I am having a problem with my ROPS #1
KiotiSteve
Connecticut
Kioti CK30 HST
CK30 HST - I am having a problem with my ROPS. When I go to lower the ROPS it comes into contact with the fender on the left side. It occurs when I have lowered them about half way. If I continued to lower the ROPS it would do some serious damage to the fender. I contacted the dealer that I purchased the tractor from and they in turn contacted Kioti. The response I received is that there is no spacer kit or other recommended repair. It is a manufacturing defect and there is nothing that can be done about it! /forums/images/graemlins/confused.gifI was told I would have to remove the ROPS in order to garage the machine. Any suggestions would be appreciated.
/ I am having a problem with my ROPS #2
That can't be right, mine clears fine, it has to be something out of line, maybe the fender can be adjusted. I'd sure contact Kioti through another source, sounds like your dealer is blowing smoke. I can't believe they'd tell you to remove the ROPS, that's a lot of work and would take a crane.
/ I am having a problem with my ROPS #3
</font><font color="blue" class="small">( I was told I would have to remove the ROPS in order to garage the machine. Any suggestions would be appreciated. )</font>
That would be real smart of any dealer to tell someone to remove the ROPS. /forums/images/graemlins/confused.gif An accident waiting to happen.
murph
/ I am having a problem with my ROPS #4
What's the latest?
/ I am having a problem with my ROPS #5
Mech, do you have the older model ROPS... The reason I ask is because the new Rops fold in the middle, it would be impossible in my view to have it touch the fender, keep us posted...cag
/ I am having a problem with my ROPS #6
In 05 my CK folds in the center but I have seen some CKs that fold near the base.
Picture of left side. This is the one giving me problems.
Here is approximately the same view of the right side.
Here again is the left side straight on. You can see the tolerance is very close. As you lower the ROPS the left side comes into contact with the fender about 50 percent of the way down.
Yes, I do have the older style. It looks to me like the vertical members of the frame that the ROPS are assembled to are not parallel.
/ I am having a problem with my ROPS #11
I wonder if your fender isn't pushed in on that side. There are four bolts holding it on in that area, if you can't see a reason for it being closer than normal, I'd put some spacers between the fender and it's mount to space it out. Here is a pic of my left side folded from the top and the bottom.
/ I am having a problem with my ROPS #12
/ I am having a problem with my ROPS #13
Mech From your pics looks like you have the older type rops, the pics clearly shows the rops to be slightly off center which in my view would explain your current problem... This should be look at more closely by your dealer after all you did buy a tractor with foldable rops... This problem could be easily fix by shimming one side of the rops, I'm not suggesting for you to do that because of safety issues regarding rops (look up your manual) if I were you I would pressure the dealer to fix it ...cag
/ I am having a problem with my ROPS #14
Cag is right, you really shouldn't have to touch it, it's supposed to fold without damaging the fender.
/ I am having a problem with my ROPS #15
Mech you answered my question about the rops while I was replying,I have the same rops as Red, is pics can give you an idea of spacing even do there the new type keep us posted...cag
Redrocker thank you for the pictures. I just went and looked to make sure that the fender wasn't pushed in and it looks OK to me. If I were to shim out the fender it looks like it would create a gap between the fender and frame where debris could get stuck and chafe the paint away, etc. Also it would weaken the shift support that gets quite a bit of hard use as it is. It would definitely allow the ROPS to be lowered but I think create other problems.
/ I am having a problem with my ROPS #17
You're right, the dealer assembles all that stuff, that may be his reluctance to fix it. It's got to be adjustable in there somewhere. I'd get all over him to make it right.
Thanks CAG and Redrocker and all that have contributed , I did not have much success with the dealer. They are located about 100 miles from where I live. I got the impression that they don’t see me as a repeat customer and just brushed me off. They told me that there was nothing they could do. They showed no interest in helping me at all. I very pleasantly said that I was going to contact Kioti and see if they had a fix. They said “good luck”. So now you can see where this was going so I loaded the tractor up and headed for home. Frankly, they don’t have the kind of facility to do a major repair job anyways. To do the repair correctly I would think that the ROPS and frame would have to be removed. The welds to the mounting plates that attach to the axel ground out correctly aligned and re-welded. Their operation is more geared to small garden tractors and lawnmowers. The reason I bought from them is that they had the CK30-HST in stock and they actually returned my phone calls! The other local dealers I contacted were less than enthusiastic in dealing with me because I did not want something off their lots. I actually had one dealer tell me that he would call me with a price on a CK30-HST when he got one in. He would not give me a quote even though I was there at his lot, not just calling on the phone. (He has never called!) All that being said, I like my tractor. But the few dealers in my area leave something to be desired. My hat is off to the good dealers I see posting on this forum and I am envious of those who are luck enough to live close by them. I needed that little catharsis, now I have to concentrate on the repairs.
/ I am having a problem with my ROPS #19
Since the ROPS is frame mounted and the "body" of the tractor is mounted to the frame is there perhaps a way to shift the body to allow enough gap? If the gap is too big on one side and too small on the other maybe a little shove with the body mounts loosened may be in order. I've done it with jeeps. Worth a look anyway, but not worth causing a problem with the other side.
Thanks Highbeam, I went out and checked with a flashlight (because I can’t get it inside) and it looks as if the mounting bolts for the body are not adjustable. They are not slotted in any and are welded to the sheet metal. They then bolt directly into the rear gear housing. Nice suggestion though, Thanks.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A59230)
2017 GMC Sierra...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
