I am having a problem with my ROPS
   / I am having a problem with my ROPS #1
KiotiSteve
Connecticut
Kioti CK30 HST
CK30 HST - I am having a problem with my ROPS. When I go to lower the ROPS it comes into contact with the fender on the left side. It occurs when I have lowered them about half way. If I continued to lower the ROPS it would do some serious damage to the fender. I contacted the dealer that I purchased the tractor from and they in turn contacted Kioti. The response I received is that there is no spacer kit or other recommended repair. It is a manufacturing defect and there is nothing that can be done about it! /forums/images/graemlins/confused.gifI was told I would have to remove the ROPS in order to garage the machine. Any suggestions would be appreciated.
   / I am having a problem with my ROPS #2
That can't be right, mine clears fine, it has to be something out of line, maybe the fender can be adjusted. I'd sure contact Kioti through another source, sounds like your dealer is blowing smoke. I can't believe they'd tell you to remove the ROPS, that's a lot of work and would take a crane.
   / I am having a problem with my ROPS #3
</font><font color="blue" class="small">( I was told I would have to remove the ROPS in order to garage the machine. Any suggestions would be appreciated. )</font>
That would be real smart of any dealer to tell someone to remove the ROPS. /forums/images/graemlins/confused.gif An accident waiting to happen.
murph
   / I am having a problem with my ROPS #4
What's the latest?
   / I am having a problem with my ROPS #5
Mech, do you have the older model ROPS... The reason I ask is because the new Rops fold in the middle, it would be impossible in my view to have it touch the fender, keep us posted...cag
   / I am having a problem with my ROPS #6
In 05 my CK folds in the center but I have seen some CKs that fold near the base.
Picture of left side. This is the one giving me problems.
Here is approximately the same view of the right side.
Here again is the left side straight on. You can see the tolerance is very close. As you lower the ROPS the left side comes into contact with the fender about 50 percent of the way down.
Yes, I do have the older style. It looks to me like the vertical members of the frame that the ROPS are assembled to are not parallel.
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
MAHINDRA EMAX 225 TRACTOR (A51243)
MAHINDRA EMAX 225...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
John Deere 7000 8 R Planter (A50515)
John Deere 7000 8...
