Hydrostatic stall
/ Hydrostatic stall #1
Diggingwithdiesel
Kubota B3030
I was pushing under a log and lifting when the tractor stalled before I could release pressure. Immediately tried to restart it, but it won’t turn over at all. I have power, radio and gauges work. I’m thinking hydrostatic pressure must be relieved for engine to turn over. Any suggestions?
/ Hydrostatic stall #2
Did you release hydro pressure by cycling the pedals?
/ Hydrostatic stall #6
With travel pedals in neutral their will be no hydrostatic load on the engine so like others have stated the problem is something else probably safety switch related.
/ Hydrostatic stall #8
Ive stalled hydrostats in the past, never anything needing to do but restart unit.
/ Hydrostatic stall #9
what model and type tractor?
/ Hydrostatic stall #11
Make sure the hydrostatic pedals are centered. Every once in a while mine when I stall mine the pedals don't come all the way back to center and there must be a safety that prevents it from starting with a pedal depressed.
/ Hydrostatic stall #12
On Kubotas at least there is indeed a switch connected to the hst treadle mechanism. When the treadle is centred the switch is positioned so the tractor will turn over. It is a push button type switch, at least on mine.
On my mx5100 it is on the left side down underneath. To find it follow the hst treadle linkage. It may be out of adjustment in which case it should start by holding the key engaged and fooling with the treadle gently back and forth.
However the switch may be broken in which it won't start. This happened to me while piling brush. Shut off for lunch and it would not start. Found the switch had broken from brush.
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2011 STEPHENS 200BBL CRUDE TANKER (A65643)
2011 STEPHENS...
2014 Freightliner M2 106 Water Truck, VIN # 1FVACXDTXEHFU5910 (A65563)
2014 Freightliner...
