Hydrostatic drive...Does direction matter?
/ Hydrostatic drive...Does direction matter? #1
jamtuc
Kentucky
John Deere 3720
Just wondering if it matters which direction that a hydro drive tractor was driven fwd or revervse. :confused3:
/ Hydrostatic drive...Does direction matter? #2
no clue myself but unless it has straight cut gears there is a "stronger" drive direction as the teeth pull into the helical vs push against it.
Mark
/ Hydrostatic drive...Does direction matter? #3
I am not sure what you are asking.
/ Hydrostatic drive...Does direction matter? #4
Only to the operator!!
/ Hydrostatic drive...Does direction matter? #5
i would imagine it should not matter. granted there is normally more "forward" gears vs reverse gears (hi, med, low) like settings. were you can go faster in forward vs reverse. there is "power" hydro transmission, same amount of gears forward and reverse for (hi,med,low) that may give you exactly same speed forward and reverse.
SPIKER most likely has it though, various gears and more so the teeth on them. i would imagine you would have more forward umph and less tear and wear driving forward vs reverse.
though now that i think about it some... i am trying to figure out what actual reversing stuff i do, that would even come close to what i put on tractor when i drive forward... back dragging, that is not a big one.
i am not attaching anything to tractor FEL and driving backward, nor or 3pt hitch... normally only time reverse see's any sort of action is once i loaded something up on FEL or on 3pt hitch and backing up.
i suppose backing up hill in reverse, i have had to do that a few times.
heck i really can't think of anything were i might jamb something while in reverse and give everything a good shake down. vs what i have done in forward motion.
getting stuck in mud/snow/ice and using FEL and backhoe to push/pull me along. but transmission and gears really not taking a beating in reverse due to tires slipping and sliding.
going in reverse more fragile? thinking about maybe more than i would have thought?
/ Hydrostatic drive...Does direction matter? #6
The HST itself won't care. Pretty sure it works the same fwd or reverse, just crossing the output pipe to change direction. Helical gears are stronger forward vs reverse, as is the traction on R1 at tires & to a lesser degree R4 industrials.
/ Hydrostatic drive...Does direction matter? #7
My Massey does not have near the power in reverse as it does in forward.
/ Hydrostatic drive...Does direction matter? #8
forward.
That's interesting. An HST in FWD or REV uses the same variable-displacement piston pump to drive the
same fixed (usually) displacement piston motor. Going from one direction or the other is accomplished by
tilting the swash plate on the pump one way or the other. There is a separate RV for FWD and REV, but all
I have seen internally (Kubota, JD, Kioti, McCormick) use the same pressure setting for either direction. All
gears are the same.
Could you be experiencing a lower traction condition in REV, vs. FWD? R1 and R4 tires do much better
in FWD.
/ Hydrostatic drive...Does direction matter? #9
Ed,
Did you mean less speed in reverse Vs forwrd or less power. I believe most HST tractors have limited or reduced speed in reverse Vs forwards for safety purposes.
/ Hydrostatic drive...Does direction matter? #10
And then you have something like my Power Trac, where every wheel has its own hydraulic motor, and one variable volume pump powers all of them, so no gears. It goes 8mph forward or reverse. But that's not a very common setup among "real" tractors. :laughing:
/ Hydrostatic drive...Does direction matter? #11
heck i really can't think of anything were i might jamb something while in reverse and give everything a good sake down. vs what i have done in forward motion.
I think you ARE CORRECT that REVERSE gearing IS NOT as strong as in drive. The Helical Cut type gearing can actually push itself out of gear on gear drive tractors as you load up the system. I often have issues with my gear drive tractor for that reason backing up under load pops it out of gear. The worst was when I was DRIVING FORWARD with my trailer and 6 or 7Klbs of logs on back down the road to neighbors sawmill. 15% or better grade and the trailer weight pushed my creeper gearbox OUT of gear because of the overriding push of the trailer & I was using engine braking... :eek: Needless to say the brakes were useless had to slam the FEL into the road AND drop the back blade/trailer onto the road surface. It was FRESH tar/chip that week. On way back I re-flattened the speed-bump I created :embarrassed: but at least the rippers were all up :thumbsup: ;) :D
yep those are nice, same with the Ventrac and Steiner yard/garden type mowers/tractors. Really nice machines but LOTS of $$$$...
Mark
/ Hydrostatic drive...Does direction matter? #12
Mark
Our Power Trac was very reasonably priced for what we got. The Ventracs and Steiners have much better fit and finish, and are quite a bit more expensive than the PT. Kind of limited in what they will do for our needs. So we went with the PT.
LIPPMANN HEAVY DUTY ROCK SORTER (A66734)
LIPPMANN HEAVY...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2007 BIG TEX 20 T/A UTILITY TRAILER (A67714)
2007 BIG TEX 20...
